Problem with shape file rendering
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Thu Jan 31 12:11:24 EST 2008
Benoît Andrieu wrote:
> Given all this, I first tried to render this with a web browser by writing directly my request :
> http://acquisitiontest/CGI/bin/mapserv.exe?request=GetMap&map=C:/temp/bch/Shell.map&request=GetMap&layers=Vector&srs=EPSG:4326&version=1.1.1&styles=
> By not giving the extent nor width and height, I am expecting to take the full bounding box of the map file as width and height. > I am already doing this for raster layers so I won't be surprised to make it work for shape files.
> But, unfortunately, the result remains empty whatever I try.
This is mostly guessing, but could it be that there is some conflict due to that you are using epsg:4326 in your request but mapfile extents are in some other projection? What happens if you change the SRS in the request to suit the map level projection? Of course it must be added to wms_srs list first.
-Jukka-
MAP
Name"Shell"
CONFIG "PROJ_LIB" "c:\Inetpub\wwwroot\Cgi\proj_lib\"
EXTENT 277486 5873890 691772 6823080
SIZE 512 512
IMAGETYPE PNG24
IMAGECOLOR 255 255 255
UNITS METERS
OUTPUTFORMAT NAME PNG24 DRIVER "GD/PNG" MIMETYPE "image/png" EXTENSION PNG IMAGEMODE RGBA TRANSPARENT ON END
PROJECTION "+proj=tmerc +lat_0=0 +lon_0=0 +k=0.999600 +x_0=500000 +y_0=0 +ellps=intl +units=m +no_defs" END
WEB
IMAGEPATH "c:\ms_tmp\"
IMAGEURL "http://ACQUISITIONTEST/ms_tmp"
METADATA
"wms_title" "Ob135_200"
"wms_srs" "epsg:4326"
"wms_onlineresource" "http://ACQUISITIONTEST/WMS/Default.aspx?MapId=8"
END
END
SYMBOL
NAME "quadrat"
TYPE VECTOR
POINTS
0 0
0 1
1 1
1 0
END
FILLED TRUE
END
LAYER
NAME "Vector"
TYPE POINT
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "C:/temp/bch/gbr_rigs.shp"
DATA "gbr_rigs"
CLASS
SYMBOL "quadrat"
COLOR 255 0 0
OUTLINECOLOR 0 0 0
SIZE 6
END
END
END
By not giving the extent nor width and height, I am expecting to take the full bounding box of the map file as width and height. I am already doing this for raster layers so I won't be surprised to make it work for shape files.
So, I remembered to use the shp2img to make a render and there I have a correct result.
