MapServer 5.0 demo problem
Pericles S. Nacionales
naci0002 at UMN.EDU
Thu Jan 31 17:07:21 EST 2008
Jill,
The IMAGEPATH and IMAGEURL variables are defined in the Javascript code
near the top of index.html. Change the paths there and you should be set.
-Perry
Fawcett, David wrote:
> Jill,
> It looks like you need to modify your map file. You need to change the
> value for imagepath to reflect the path to your mapserver temp
> directory. The value should likely be "C:\ms4w\tmp\ms_tmp" or
> "C:\ms4w\tmp".
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Jill Recla
> Sent: Thursday, January 31, 2008 1:19 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] MapServer 5.0 demo problem
> Hi everyone,
> I decided to uninstall everything I had and start from scratch. I
> installed MS4W with MapServer 5.0 and am now trying to get the 5.x demo
> to work. MapServer and all of the other MS4W components are working
> properly, and the initial index.html page loads. When I try to
> initialize the webpage, however, I get this error:
> msSaveImageGD(): Unable to access file. Unable to open file
> /usr/local/www/docs_maps/tmp/ITASCA12018069395076.png for writing
> I have changed my index.html file to look like this:
> <!-- EDIT THE FORM ACTION -->
> <form name="demo" method="GET" action="/cgi-bin/mapserv.exe"
> onSubmit="configure()">
> <input type="hidden" name="layer" value="lakespy2">
> <input type="hidden" name="layer" value="dlgstln2">
> <input type="hidden" name="zoomsize" value=2>
> <input type="hidden" name="map_web" value="">
> <!-- EDIT THESE HIDDEN VARIABLES -->
> <input type="hidden" name="map"
> value="C:/ms4w/Apache/htdocs/workshop-5.0/itasca.map">
> <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
> <input type="hidden" name="root"
> value="C:/ms4w/Apache/htdocs/workshop-5.0/">
> Does anyone know how to fix this?? There must be something simple I'm
> not changing, but I can't figure out what it is.....
> Thanks,
> Jill
