[mapserver-users] GetFeatureInfo from PostGis database
"SAEZ Laurent - CETE Méditerr./DI/ETER"
Laurent.Saez at developpement-durable.gouv.fr
Tue Jul 1 01:48:51 EDT 2008
I've tried to use the gid column, but the getfeatureinfo reports me an
error :
"Postgresql reports the error as 'ERREUR: la colonne «gid»
n'existe pas
The error tells me that the gid column doesn't exist. You can trust me,
I have a field called gid.
Thanks
Le 30/06/2008 19:49, > Bart van den Eijnden (OSGIS) (par Internet) a
écrit :
> You shouldn't use the geometry column as the unique column (USING
> UNIQUE X).
> Try an integer type column for that.
> Best regards,
> Bart
> SAEZ Laurent - CETE Méditerr./DI/ETER wrote:
>> Hi list,
>> I'm trying to access data fields using getfeatureinfo from a PostGIS
>> database.
>> I've read some articles about it, but it seems that I'm a newbie.
>> I've no problem with data access when I do some getmap requests.
>> Here is a part of my mapfile :
>> LAYER
>> NAME "bdparcellaire_numero"
>> TYPE annotation
>> STATUS ON
>> DUMP TRUE
>> TEMPLATE "blank.html"
>> MINSCALE 100
>> MAXSCALE 10000
>> CONNECTIONTYPE postgis
>> CONNECTION "user=toto password=toto
>> dbname=bdparcellaire_2007 host=172.23.208.134 port=5432"
>> DATA "the_geom FROM (select numero, feuille,
>> the_geom FROM localisant) as foo USING UNIQUE the_geom USING SRID=27582"
>> LABELITEM "numero"
>> CLASS
>> LABEL
>> TYPE TRUETYPE
>> WRAP "#"
>> COLOR 0 0 0
>> OUTLINECOLOR 254 254 254
>> FONT arial
>> SIZE 9
>> POSITION CC
>> FORCE false
>> PARTIALS false
>> END
>> END
>> METADATA
>> WMS_TITLE "Numéros de parcelle (Données BD Parcellaire® -
>> Copyright IGN)"
>> wms_abstract "Visible entre les échelles 1/100 et 1/10
>> 000" wms_srs "EPSG:27582 EPSG:27581 EPSG:27583
>> EPSG:27584 EPSG:27591 EPSG:27592 EPSG:27593 EPSG:27594 EPSG:2154
>> EPSG:23030 EPSG:23031 EPSG:23032 EPSG:32630 EPSG:32631 EPSG:32632
>> EPSG:4326"
>> wms_extent "47650 1620400 1197850 2677450"
>> WMS_ENCODING "UTF-8"
>> GML_INCLUDE_ITEMS "all"
>> END
>> END
>> When I try this getfeatureinfo request, the XML returned is not
>> complete :
>> The request :
>> http://myIP/cgi-bin/mapserv?map=/data/carto/ref/bdparcellaire/bdparcellaire_2007_direct.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&SRS=EPSG%3A27582&WIDTH=600&HEIGHT=400&BBOX=643470,1743572,643590,1743652&LAYERS=bdparcellaire_numero&STYLES=&FORMAT=image%2Fpng&QUERY_LAYERS=bdparcellaire_numero&X=167&Y=175&INFO_FORMAT=application%2Fvnd.ogc.gml&FEATURE_COUNT=999
>> The entire XML :
>> <?xml version="1.0" encoding="UTF-8"?>
>> <msGMLOutput
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> <bdparcellaire_numero_layer>
>> Why it doesn't work ?
>> I know that it should be in my DATA object in my mapfile, but I don't
>> know what exactly...
>> Thanks a lot...
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
