[mapserver-users] Postgis mapserver sql help
Alexandre Busquets Triola
alex at sigte.udg.edu
Wed Jul 2 05:48:47 EDT 2008
Thanks Guillaume
the final code is
geom FROM (select codi, geom FROM par_vit3
where intersects(
select GeomFromText(
'POLYGON((258000 4485000, 258000 4625800 ,398800 4625800, 398800
4485000, 258000 4485000))',23031)
as consulta1
, geom )
AND codi IS NOT NULL
) as consulta2
using unique codi using SRID=23031
En/na Guillaume Sueur ha escrit:
> Hi,
> try this :
> geom FROM (select id, geom FROM par_vit3
> where intersects(
> 4625800 ,398800 4485000, 258000 4485000))',23031)
> , geom )
> using unique id using SRID=23031
> Note that I've added an id field to the SQL. Adapt it to your own id
> field.
> Guillaume
> Alexandre Busquets Triola a écrit :
>> Hi, this is the first time that I write to the list.
>> I'm working with mapserver and postgis and I have a problem with
>> mpaserver,
>> if I put this query on postgres
>> select geom FROM par_vit3 where intersects(
>> 'POLYGON((258000 4485000, 258000 4625800 ,398800 4625800 ,398800
>> ) as foo
>> , geom )
>> works ok
>> but if I put this
>> ) as foo using SRID=23031
>> , geom ) using SRID=23031
>> in maperver not works, this is the error that I have
>> Warning: [MapServer Error]: prepare_database(): Error executing
>> POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor
>> BINARY CURSOR FOR SELECT
>> asbinary(force_collection(force_2d(geom)),'NDR'),OID::text from
>> par_vit3 where intersects( ( select GeomFromText( 'POLYGON((258000
>> 4485000, 258000 4625800 ,398800 4625800 ,398800 4485000, 258000
>> 4485000))',23031 ) as foo WHERE geom && setSRID('BOX3D(258000
>> 4485000,398800 4625800)'::BOX3D, 23031 )' Postgresql reports the
>> error as 'ERROR: syntax error at end of input LINE 5:
>> ...tSRID('BOX3D(258000 4485000,398800 4625800)'::BOX3D, 23031 ) ^ '
>> More Help: Error with POSTGIS data variable. You specified 'check
>> your .map file'. Standard ways of specifiying are : (1)
>> 'geometry_column from geometry_table' (2) 'geometry_column from (sub
>> query) as foo using unique column name using SRID=srid#' Make sure
>> you put in the 'using unique column name' and 'using SRID=#' clauses
>> in. For more help, please in
>> D:\alex\webs\alex\codorniu\mapscript\parceles2.php on line 172
>> Warning: [MapServer Error]: msPOSTGISLayerRetrievePK(): Error
>> executing POSTGIS statement (msPOSTGISLayerRetrievePK():select
>> attname from pg_attribute, pg_constraint, pg_class where
>> pg_constraint.conrelid = pg_class.oid and pg_class.oid =
>> pg_attribute.attrelid and pg_constraint.contype = 'p' and
>> pg_constraint.conkey[1] = pg_attribute.attnum and pg_class.relname =
>> 'par_vit3 where intersects( ( select GeomFromText( 'POLYGON((258000
>> 4485000))',23031 ) as foo' and pg_table_is_visible(pg_class.oid) and
>> pg_constraint.conkey[2] is null in
>> Thanks
_________________________________________________________________
Servei de Sistemes d'Informació Geogràfica i Teledetecció (SIGTE)
Universitat de Girona
Pl. Ferrater Mora, 1
17071 Girona
Tel. 972 41 80 39 Fax. 972 41 82 30
http://www.sigte.udg.es/
