[mapserver-users] Mapserver 5 migration & PostGIS
Ben Brehmer
bbrehmer at refractions.net
Fri Jul 4 17:57:22 EDT 2008
Dear All,
I'm just in the process of changing all of my mapfiles to be 5.x
compatible.
The PostGIS layer[1] which worked fine with 4.6 now throws an odd error
[2] in 5.0.3. If you look at the error, you will notice that the query
has ""::text prepended to it although this is not in the DATA statement.
It deosn't seem to matter how I manipulate the DATA statement, it always
has an empty string prepended to it at runtime which causes this error.
Any ideas why an empty string is prepended to a PostGIS query at runtime
in Mapserver 5?
Thanks,
Ben Brehmer
[1]
LAYER
NAME "pointlayer"
DATA "the_geom FROM points"
CONNECTIONTYPE postgis
CONNECTION "host=localhost user=postgres port=5432 dbname=xxx
password=xxx"
[2]
msDrawMap(): Image handling error. Failed to draw layer named
'pointlayer'. prepare_database(): Query error. Error declaring cursor:
ERROR: zero-length delimited identifier at or near """" at character 43
With query string: DECLARE mycursor BINARY CURSOR FOR SELECT
""::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
from points WHERE the_geom && setSRID('BOX3D(-13692533.9246539
5944251.98072804,-13537311.7862516 6063067.47212323)'::BOX3D,
find_srid('','points','the_geom') )
