[mapserver-users] How to query attributes via WMS
Bruce Cheney
BLC at JUB.com
Mon Jul 7 19:06:37 EDT 2008
Steve,
I believe I misunderstood what you are doing. Maybe a slight
clarification would be helpful. I see three different options:
1. Create a Mapserver WMS that feeds into the Google Maps API (Google
API controls display) = allowed
2. Use Google Maps as a WMS to feed into Mapserver on the server side
(Mapserver API controls display) = not allowed
3. Use Google Maps to mesh with Mapserver data on client side (example:
Open layers meshes two on client side - Openlayers controls) = allowed
If I understand you correctly you are using #1 where Google Maps is the
controlling environment.
I thought you were implementing #2.
For a MapServer discussion reference on this not being allowed see:
http://www.nabble.com/Google-Summer-of-Code-Ideas-td9378841.html#a939953
8
<BLOCKED::http://www.nabble.com/Google-Summer-of-Code-Ideas-td9378841.ht
ml#a9399538> Refer to Jan and Daniel's comments.
Obviously this is not an official statement. Maybe someone has an
official statement from Google that they could post?
Bruce Cheney
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Steve
White
Sent: Monday, July 07, 2008 2:19 PM
To: Bruce Cheney; 'Mapserver-users'
Subject: RE: [mapserver-users] How to query attributes via WMS
Bruce -
I don't see anything in Google's T&Cs that disallow adding layered tiles
over their own. In fact since the API has a class called
GTileLayerOverlay it looks like they are encouraging it.
http://code.google.com/apis/maps/documentation/reference.html#GTileLayer
Overlay
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bruce
Cheney
Sent: 07 July 2008 20:28
To: Mapserver-users
I am not answering your question - sorry. Instead I have questions for
you. Will Google allow using their maps as a WMS? Did you get special
permission for this? Everything I have read says this is not allowed
from the Google side. I am asking because we would really like to use
Google as a background for our web app also and if this is a new
development then we would be interested in doing it also. Thanks.
Bruce Cheney
White
Sent: Monday, July 07, 2008 12:02 PM
To: Mapserver-users
Subject: [mapserver-users] How to query attributes via WMS
I'm using mapserver to overlay png tiles over a google maps interface
and it's working well. I have a series of shp files on the server and I
want to build a search interface so the user can query the actual data.
An example would be in simple terms: 'select all data from shp where
layer = 'thislayer' and field like '%castle%''.
Is it possible to interpret a variable if I sent it via the Url with the
WMS call? For example, I'll tag on &TestVar=castle to the WMS call. Can
the map file be set up to interpret TestVar and perform a query against
a shp file field in a given layer?
Thanks,
Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080707/85aba003/attachment.html
