[mapserver-users] Cannot display query result in popup window
kreshna_iceheart at yahoo.com
Tue Jul 8 06:28:04 EDT 2008
I'm using MapServer for Windows. I made a query on my map. The query result is displayed properly, but I cannot display it on a popup window. The query result is always displayed on the same browser window, "replacing" the map with the result.
I have added the following scripts on my template:
function toFrame() {
if (document.mapserv.mode.value == "query" || document.mapserv.mode.value == "nquery") {
document.mapserv.target = "_blank";
} else {
document.mapserv.target = "_self";
Yet the query above simply does not work; the result of the query is always displayed on the same browser window ("replacing" my map) instead of displayed in a popup window.
Am I doing the right thing? I also attach the map file, the HTML template, and the query template. Many thanks.
-Kresh
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080708/8ab79d7a/GABUNGAN-0001.obj
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080708/8ab79d7a/GABUNGAN_tmpl-0001.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080708/8ab79d7a/GABUNGAN_query_desa-0001.html
