[mapserver-users] mapscript queryByPoint - tolerance depends of
resolution ?
Oliver Christen
oliver.christen at camptocamp.com
Wed Jul 9 08:41:37 EDT 2008
Hi
I have a problem when doing a queryByPoint with phpmapscript 4.10.1
By default, the resolution of my map is 96 dpi.
I do a queryByPoint on a layer containing polygonal areas. The point is
right in the middle of one area.
I use a default tolerance (-1) corresponding, if I read correctly the
documentation, to 3 pixels.
The result obtained is the area containing the coordinates I used, it's
absolutly normal and I get what I expect.
Now, if I dynamicaly change the resolution of the map to 150 dpi and then do
exactly the same queryByPoint as before,
I get nothing!
Mapserver consider there was nothing at the coordinate I provided.
Then, if I redo the query, at 150 dpi, BUT with a tolerance set to 10
(instead of -1), I get a correct and expected result.
So, somehow, Mapserver seems to make some very weird calculation with the
tolerance and resolution which make it to believe there is nothing when then
is something.
have you ever heard of such behaviour?
is that a bug?
any help would be very welcome.
thanks in advance
Oliver
