[mapserver-users] [Scalebar] Wrong values
Fabian Rami
fabian.rami at wowcompany.com
Thu Jul 10 03:26:07 EDT 2008
Hi everyone,
I have a mistake with the scalebar.
When i use the demo with my mapfile i have meters for europe level ,
centimeters for country level and kilometers for street level.
I still a beginner with MapServer so if you see something wrong
please tell me :)
I use Teleatlas data, i have found the specification of the data :
Projection: Geographic (not projected)
Datum WGS84 (labeled GCS_WGS_1984 in ESRI products)
Paramaters:
•GEOGCS["GCS_WGS_1984",
•DATUM["D_WGS_1984",
•SPHEROID["WGS_1984",6378137,298.257223563]],
•PRIMEM["Greenwich",0],
•UNIT["Degree",0.017453292519943295]]
THANKS FOR YOUR HELP :o)
For the europe.map file i have the following :
MAP
NAME "EUROPE"
EXTENT -12.85 27.22 18.42 55.06
DEBUG ON
STATUS ON
#SIZE 990 684
IMAGECOLOR 250 245 200
SHAPEPATH "C:\12map\Carto\TeleAtlas"
FONTSET "C:\12map\Fonts\fonts.list"
SYMBOLSET "C:\12map\Symbols\Symbols35.sym"
UNITS Meters
IMAGETYPE gif
OUTPUTFORMAT
NAME gif
DRIVER "GD/GIF"
MIMETYPE "image/gif"
IMAGEMODE PC256
EXTENSION "gif"
END
WEB
METADATA
"max_extents" "-12.85 27.22 18.42 55.06"
# Limite gauche | limite bas | limite droite | Limite haut
END
TEMPLATE mapQuery.htm
IMAGEPATH "C:\ms4w\Apache\htdocs\tmp\"
IMAGEURL "/tmp/"
END
QUERYMAP
STYLE HILITE
COLOR 255 0 0
END
LEGEND
STATUS ON
IMAGECOLOR 192 192 192
LABEL
TYPE TRUETYPE
FONT arial
COLOR 0 0 0
SIZE 10
ANTIALIAS TRUE
END
END
# Outer World
LAYER
NAME "Outer World"
DATA "outerworld"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 100
MINSCALE 0
CLASS
COLOR 154 204 255
END
END
# COUNTRY : Belgique
LAYER
NAME "BEL - Land Use"
TILEINDEX "BEL\lu\bel_lu"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 4
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 4
MINSCALE 0.3
EXPRESSION ('[FEATTYP]' eq '7170' OR '[FEATTYP]' eq '9744')
COLOR 120 172 117 # Vert
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
OUTLINECOLOR 255 255 255
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 4
MINSCALE 0.3
EXPRESSION ('[FEATTYP]' eq '9720' OR '[FEATTYP]' eq '9715' OR
'[FEATTYP]' eq '9732' OR '[FEATTYP]' eq '9771')
COLOR 153 153 153
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
COLOR 153 153 153
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 2
MINSCALE 0.3
EXPRESSION ('[FEATTYP]' eq '9353' OR '[FEATTYP]' eq '9731' OR
'[FEATTYP]' eq '7110' OR '[FEATTYP]' eq '9745' OR '[FEATTYP]' eq '9748'
OR '[FEATTYP]' eq '9754' OR '[FEATTYP]' eq '9761' OR '[FEATTYP]' eq
'9767' OR '[FEATTYP]' eq '9768' OR '[FEATTYP]' eq '9790' OR '[FEATTYP]'
eq '9776' )
COLOR 192 192 192
END
CLASS
MAXSCALE 0.2999999
MINSCALE 0
eq '9776' )
COLOR 192 192 192
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 2
MINSCALE 0.3
EXPRESSION ('[FEATTYP]' eq '9737' OR '[FEATTYP]' eq '9738' OR
'[FEATTYP]' eq '9739' OR '[FEATTYP]' eq '9740' OR '[FEATTYP]' eq '9742'
OR '[FEATTYP]' eq '9743' OR '[FEATTYP]' eq '9753' OR '[FEATTYP]' eq '9762')
COLOR 153 153 153
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
COLOR 153 153 153
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 3
MINSCALE 0
COLOR 254 254 204
END
CLASS
MAXSCALE 3
MINSCALE 0
COLOR 254 254 204
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Land Cover"
TILEINDEX "BEL\lc\bel_lc"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 0.3
EXPRESSION ('[FEATTYP]' eq '7120')
COLOR 102 204 153 # Vert
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 7
MINSCALE 0.3
EXPRESSION ('[FEATTYP]' eq '9710')
COLOR 204 204 102 # jaune
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 7
MINSCALE 0.3
EXPRESSION ('[FEATTYP]' eq '9725')
COLOR 153 204 102 # kaki
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Water Polygones"
TILEINDEX "BEL\wa\bel_wa"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 100
MINSCALE 0
LABELITEM "NAME"
CLASS
NAME "Rivers and lakes high"
COLOR 154 204 255
MAXSCALE 100
MINSCALE 4
EXPRESSION ('[DISPCLASS]' < '2')
END
CLASS
MAXSCALE 4
MINSCALE 0
NAME "Rivers and lakes"
COLOR 154 204 255
LABEL
COLOR 51 102 204
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana_italic
SIZE 8
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Water Lines"
TILEINDEX "BEL\wl\bel_wl"
STATUS DEFAULT
TYPE LINE
MAXSCALE 4
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 4
MINSCALE 0
COLOR 154 204 255
MINSIZE 10
LABEL
COLOR 51 102 204
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana_italic
SIZE 7
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Administrative Boundaries 2"
TILEINDEX "BEL\a2\bel_a2"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 13
MINSCALE 9
OUTLINECOLOR 0 100 150
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Administrative Boundaries 7"
TILEINDEX "BEL\a7\bel_a7"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 100
MINSCALE 4
EXPRESSION ('[ID]' eq '10560032000040')
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 15
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 8.99999
MINSCALE 5
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Administrative Boundaries 8"
TILEINDEX "BEL\a8\bel_a8"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 4.99999
MINSCALE 2
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Administrative Boundaries 8 - High POPCLASS"
STATUS DEFAULT
TYPE annotation
LABELITEM "NAME"
CLASS
EXPRESSION ('[POPCLASS]' < '4')
MAXSCALE 100
MINSCALE 5
SYMBOL 'circle'
SIZE 4
COLOR 0 0 0
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 8
ANTIALIAS TRUE
POSITION ur
ANGLE auto
END
END
END
LAYER
NAME "BEL - Administrative Boundaries 9"
TILEINDEX "BEL\a9\bel_a9"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 1.99999
MINSCALE 0
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "BEL - Administrative Boundaries 0"
TILEINDEX "BEL\a0\bel_a0"
STATUS DEFAULT
MAXSCALE 100
MINSCALE 0
TYPE POLYGON
LABELITEM "NAME"
CLASS
EXPRESSION ('[ORDER00]' eq '$BE')
MAXSCALE 100
MINSCALE 0
COLOR 154 204 255
END
CLASS
EXPRESSION ('[ORDER00]' ne '$BE')
MAXSCALE 100
MINSCALE 15
OUTLINECOLOR 0 50 50
LABEL
COLOR 0 50 50
TYPE TRUETYPE
FONT verdana_bold
SIZE 9
ANTIALIAS TRUE
FORCE TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 14.99999
MINSCALE 0
OUTLINECOLOR 0 0 0
SYMBOL "dashed1"
SIZE 1.5
END
END
LAYER
NAME "BEL - Rail Roads"
TILEINDEX "BEL\rr\bel_rr"
STATUS DEFAULT
TYPE LINE
MAXSCALE 2
MINSCALE 0
CLASS
NAME "RailRoads"
MAXSCALE 2
MINSCALE 0.1
SYMBOL 'circle'
COLOR 0 0 0
SIZE 3
OVERLAYSYMBOL 'dcircle'
OVERLAYCOLOR 255 255 255
OVERLAYSIZE 2.5
END
CLASS
MAXSCALE 0.099999
MINSCALE 0
SYMBOL 'circle'
COLOR 0 0 0
SIZE 5
OVERLAYSIZE 3
END
END
LAYER
NAME "BEL - Streets 8"
TILEINDEX "BEL\08\bel_08"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.20
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.199999
COLOR 204 153 102
SYMBOL 'circle'
SIZE 1
END
CLASS
MAXSCALE 0.20
MINSCALE 0.099999
COLOR 204 153 102
SYMBOL 'circle'
SIZE 3
OVERLAYSYMBOL 'circle'
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.10
MINSCALE 0.05
COLOR 204 153 102
SYMBOL 'circle'
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
SYMBOL 'circle'
COLOR 204 153 102
SIZE 9
OVERLAYSIZE 7
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 204 153 102
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Streets 7"
TILEINDEX "BEL\07\bel_07"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.199999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 1
END
CLASS
MAXSCALE 0.20
MINSCALE 0.099999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.10
MINSCALE 0.05
COLOR 153 153 153
SYMBOL 'circle'
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
SYMBOL 'circle'
COLOR 153 153 153
SIZE 9
OVERLAYSIZE 7
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Streets 6"
TILEINDEX "BEL\06\bel_06"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.199999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 1
END
CLASS
MAXSCALE 0.20
MINSCALE 0.099999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.10
MINSCALE 0.05
COLOR 153 153 153
SYMBOL 'circle'
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
SYMBOL 'circle'
COLOR 153 153 153
SIZE 9
OVERLAYSIZE 7
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Streets 5"
TILEINDEX "BEL\05\bel_05"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.4
COLOR 153 153 153
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.399999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 153 153 153
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
SYMBOL 'circle'
COLOR 153 153 153
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.09999
MINSCALE 0.05
SYMBOL 'circle'
COLOR 153 153 153
SIZE 8
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 14
OVERLAYSIZE 12
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Streets 4"
TILEINDEX "BEL\04\bel_04"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.4
COLOR 153 153 153
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.399999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 153 153 153
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
SYMBOL 'circle'
COLOR 153 153 153
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.09999
MINSCALE 0.05
SYMBOL 'circle'
COLOR 153 153 153
SIZE 8
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 14
OVERLAYSIZE 12
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Main Highways 3"
TILEINDEX "BEL\03\bel_03"
STATUS DEFAULT
TYPE LINE
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 3.5
COLOR 255 0 0
SIZE 1
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.6
COLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.59999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 255 0 0
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
COLOR 255 0 0
SYMBOL 'circle'
SIZE 6
OVERLAYSIZE 2
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.099999
MINSCALE 0.050000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 10
OVERLAYSIZE 4
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 12
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 9
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
COLOR 255 0 0
SYMBOL 'circle'
SIZE 14
OVERLAYSIZE 8
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 10
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Main Highways 2"
TILEINDEX "BEL\02\bel_02"
STATUS DEFAULT
TYPE LINE
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 3.5
COLOR 255 0 0
SIZE 1
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.6
COLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.59999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 255 0 0
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
COLOR 255 0 0
SYMBOL 'circle'
SIZE 6
OVERLAYSIZE 2
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.099999
MINSCALE 0.050000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 10
OVERLAYSIZE 4
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 12
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 9
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
COLOR 255 0 0
SYMBOL 'circle'
SIZE 14
OVERLAYSIZE 8
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 10
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Main Highways 1"
TILEINDEX "BEL\01\bel_01"
STATUS DEFAULT
TYPE LINE
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 3.5
COLOR 255 0 0
SIZE 1
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.6
COLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.59999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 255 0 0
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
COLOR 255 0 0
SYMBOL 'circle'
SIZE 6
OVERLAYSIZE 2
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.099999
MINSCALE 0.050000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 10
OVERLAYSIZE 4
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 12
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 9
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
COLOR 255 0 0
SYMBOL 'circle'
SIZE 14
OVERLAYSIZE 8
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 10
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "BEL - Main Highways 0"
TILEINDEX "BEL\00\bel_00"
STATUS DEFAULT
TYPE LINE
MAXSCALE 20
MINSCALE 0
LABELITEM "ROUTENUM"
CLASS
MAXSCALE 20
MINSCALE 13
COLOR 255 100 0
SYMBOL 'circle'
SIZE 2
LABEL
OUTLINECOLOR 0 120 0
COLOR 255 255 255
MINDISTANCE 150
TYPE TRUETYPE
FONT verdana_bold
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 13
MINSCALE 3.5
COLOR 255 51 0
SYMBOL 'circle'
SIZE 3
OVERLAYCOLOR 255 221 0
OVERLAYSIZE 1
LABEL
COLOR 255 255 255
MINDISTANCE 150
TYPE TRUETYPE
FONT verdana_bold
SIZE 7
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.4
COLOR 255 51 0
SYMBOL 'circle'
SIZE 4
OVERLAYSIZE 2
LABEL
COLOR 255 255 255
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana_bold
SIZE 8
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 0.399999
MINSCALE 0.05
COLOR 255 51 0
SYMBOL 'circle'
SIZE 8
OVERLAYSIZE 4
LABEL
COLOR 255 255 255
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana_bold
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0
SYMBOL 'circle'
COLOR 255 51 0
SIZE 14
OVERLAYSIZE 10
LABEL
COLOR 255 255 255
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana_bold
SIZE 11
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
# COUNTRY : Luxembourg
LAYER
NAME "LUX - Land Use"
TILEINDEX "LUX\lu\lux_lu"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 4
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 4
MINSCALE 0.3
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 4
MINSCALE 0.3
COLOR 153 153 153
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
COLOR 153 153 153
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 2
MINSCALE 0.3
eq '9776' )
COLOR 192 192 192
END
CLASS
MAXSCALE 0.2999999
MINSCALE 0
eq '9776' )
COLOR 192 192 192
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 2
MINSCALE 0.3
COLOR 153 153 153
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
COLOR 153 153 153
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 3
MINSCALE 0
COLOR 254 254 204
END
CLASS
MAXSCALE 3
MINSCALE 0
COLOR 254 254 204
LABEL
COLOR 0 51 153
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "LUX - Land Cover"
TILEINDEX "LUX\lc\lux_lc"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 0.3
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 7
MINSCALE 0.3
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 7
MINSCALE 0.3
END
CLASS
MAXSCALE 0.299999
MINSCALE 0
LABEL
COLOR 0 102 51
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "LUX - Water Polygones"
TILEINDEX "LUX\wa\lux_wa"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 100
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 4
MINSCALE 0
COLOR 154 204 255
LABEL
COLOR 51 102 204
TYPE TRUETYPE
MINDISTANCE 150
FONT verdana_italic
SIZE 8
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "LUX - Administrative Boundaries 1"
TILEINDEX "LUX\a1\lux_a1"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 13
MINSCALE 9
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "LUX - Administrative Boundaries 4"
TILEINDEX "LUX\a7\lux_a7"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 8.99999
MINSCALE 5
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "LUX - Administrative Boundaries 8"
TILEINDEX "LUX\a8\lux_a8"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 4.99999
MINSCALE 2
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "LUX - Administrative Boundaries 8 - High POPCLASS"
STATUS DEFAULT
TYPE annotation
LABELITEM "NAME"
CLASS
MAXSCALE 100
MINSCALE 5
SYMBOL 'circle'
SIZE 4
COLOR 0 0 0
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 8
ANTIALIAS TRUE
POSITION ur
ANGLE auto
END
END
END
LAYER
NAME "LUX - Administrative Boundaries 9"
TILEINDEX "LUX\a9\lux_a9"
STATUS DEFAULT
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 1.99999
MINSCALE 0
SYMBOL 'dashed3'
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
LAYER
NAME "LUX - Administrative Boundaries 0"
TILEINDEX "LUX\a0\lux_a0"
STATUS DEFAULT
MAXSCALE 100
MINSCALE 0
TYPE POLYGON
LABELITEM "NAME"
CLASS
MAXSCALE 100
MINSCALE 15
LABEL
COLOR 0 50 50
TYPE TRUETYPE
FONT verdana_bold
SIZE 9
ANTIALIAS TRUE
FORCE TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 14.99999
MINSCALE 0
OUTLINECOLOR 0 0 0
SYMBOL "dashed1"
SIZE 1.5
END
END
LAYER
NAME "LUX - Rail Roads"
TILEINDEX "LUX\rr\lux_rr"
STATUS DEFAULT
TYPE LINE
MAXSCALE 2
MINSCALE 0
CLASS
MAXSCALE 2
MINSCALE 0.1
SYMBOL 'circle'
COLOR 0 0 0
SIZE 3
OVERLAYSIZE 2.5
END
CLASS
MAXSCALE 0.099999
MINSCALE 0
SYMBOL 'circle'
COLOR 0 0 0
SIZE 5
OVERLAYSIZE 3
END
END
LAYER
NAME "LUX - Streets 8"
TILEINDEX "LUX\08\lux_08"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.20
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.199999
COLOR 204 153 102
SYMBOL 'circle'
SIZE 1
END
CLASS
MAXSCALE 0.20
MINSCALE 0.099999
COLOR 204 153 102
SYMBOL 'circle'
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.10
MINSCALE 0.05
COLOR 204 153 102
SYMBOL 'circle'
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
SYMBOL 'circle'
COLOR 204 153 102
SIZE 9
OVERLAYSIZE 7
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 204 153 102
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Streets 7"
TILEINDEX "LUX\07\lux_07"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.199999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 1
END
CLASS
MAXSCALE 0.20
MINSCALE 0.099999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.10
MINSCALE 0.05
COLOR 153 153 153
SYMBOL 'circle'
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
SYMBOL 'circle'
COLOR 153 153 153
SIZE 9
OVERLAYSIZE 7
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Streets 6"
TILEINDEX "LUX\06\lux_06"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.199999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 1
END
CLASS
MAXSCALE 0.20
MINSCALE 0.099999
COLOR 153 153 153
SYMBOL 'circle'
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.10
MINSCALE 0.05
COLOR 153 153 153
SYMBOL 'circle'
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
SYMBOL 'circle'
COLOR 153 153 153
SIZE 9
OVERLAYSIZE 7
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Streets 5"
TILEINDEX "LUX\05\lux_05"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.4
COLOR 153 153 153
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.399999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 153 153 153
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
SYMBOL 'circle'
COLOR 153 153 153
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.09999
MINSCALE 0.05
SYMBOL 'circle'
COLOR 153 153 153
SIZE 8
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 14
OVERLAYSIZE 12
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Streets 4"
TILEINDEX "LUX\04\lux_04"
STATUS DEFAULT
TYPE LINE
MAXSCALE 0.60
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 0.60
MINSCALE 0.4
COLOR 153 153 153
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.399999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 153 153 153
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
SYMBOL 'circle'
COLOR 153 153 153
SIZE 5
OVERLAYSIZE 3
END
CLASS
MAXSCALE 0.09999
MINSCALE 0.05
SYMBOL 'circle'
COLOR 153 153 153
SIZE 8
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025
SYMBOL 'circle'
COLOR 153 153 153
SIZE 12
OVERLAYSIZE 10
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
SYMBOL 'circle'
COLOR 153 153 153
SIZE 14
OVERLAYSIZE 12
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Main Highways 3"
TILEINDEX "LUX\03\lux_03"
STATUS DEFAULT
TYPE LINE
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 3.5
COLOR 255 0 0
SIZE 1
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.6
COLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.59999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 255 0 0
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
COLOR 255 0 0
SYMBOL 'circle'
SIZE 6
OVERLAYSIZE 2
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.099999
MINSCALE 0.050000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 10
OVERLAYSIZE 4
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 12
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 9
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
COLOR 255 0 0
SYMBOL 'circle'
SIZE 14
OVERLAYSIZE 8
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 10
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Main Highways 2"
TILEINDEX "LUX\02\lux_02"
STATUS DEFAULT
TYPE LINE
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 3.5
COLOR 255 0 0
SIZE 1
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.6
COLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.59999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 255 0 0
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
COLOR 255 0 0
SYMBOL 'circle'
SIZE 6
OVERLAYSIZE 2
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.099999
MINSCALE 0.050000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 10
OVERLAYSIZE 4
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 12
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 9
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
COLOR 255 0 0
SYMBOL 'circle'
SIZE 14
OVERLAYSIZE 8
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 10
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Main Highways 1"
TILEINDEX "LUX\01\lux_01"
STATUS DEFAULT
TYPE LINE
MAXSCALE 7
MINSCALE 0
LABELITEM "NAME"
CLASS
MAXSCALE 7
MINSCALE 3.5
COLOR 255 0 0
SIZE 1
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.6
COLOR 255 0 0
SYMBOL 'circle'
SIZE 2
END
CLASS
MAXSCALE 0.59999
MINSCALE 0.2
SYMBOL 'circle'
COLOR 255 0 0
SIZE 3
OVERLAYSIZE 1
END
CLASS
MAXSCALE 0.199999
MINSCALE 0.1
COLOR 255 0 0
SYMBOL 'circle'
SIZE 6
OVERLAYSIZE 2
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 7
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.099999
MINSCALE 0.050000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 10
OVERLAYSIZE 4
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 8
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0.025000
COLOR 255 0 0
SYMBOL 'circle'
SIZE 12
OVERLAYSIZE 6
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 9
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
CLASS
MAXSCALE 0.024999
MINSCALE 0
COLOR 255 0 0
SYMBOL 'circle'
SIZE 14
OVERLAYSIZE 8
LABEL
COLOR 0 0 0
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana
SIZE 10
ANTIALIAS TRUE
POSITION CC
PARTIALS true
BUFFER 0
END
END
END
LAYER
NAME "LUX - Main Highways 0"
TILEINDEX "LUX\00\lux_00"
STATUS DEFAULT
TYPE LINE
MAXSCALE 20
MINSCALE 0
CLASS
MAXSCALE 20
MINSCALE 13
COLOR 255 100 0
SYMBOL 'circle'
SIZE 2
LABEL
COLOR 255 255 255
MINDISTANCE 150
TYPE TRUETYPE
FONT verdana_bold
SIZE 6
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 13
MINSCALE 7
COLOR 255 51 0
SYMBOL 'circle'
SIZE 3
OVERLAYSIZE 1
LABEL
COLOR 255 255 255
MINDISTANCE 150
TYPE TRUETYPE
FONT verdana_bold
SIZE 7
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
NAME "Motorways"
MAXSCALE 6.999999
MINSCALE 3.5
COLOR 255 51 0
SYMBOL 'circle'
SIZE 3.5
OVERLAYSIZE 1.5
LABEL
COLOR 255 255 255
MINDISTANCE 150
TYPE TRUETYPE
FONT verdana_bold
SIZE 8
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 3.499999
MINSCALE 0.4
COLOR 255 51 0
SYMBOL 'circle'
SIZE 5
OVERLAYSIZE 2
LABEL
COLOR 255 255 255
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana_bold
SIZE 8
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 0.399999
MINSCALE 0.05
COLOR 255 51 0
SYMBOL 'circle'
SIZE 8
OVERLAYSIZE 4
LABEL
COLOR 255 255 255
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana_bold
SIZE 10
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
CLASS
MAXSCALE 0.049999
MINSCALE 0
SYMBOL 'circle'
COLOR 255 51 0
SIZE 11
OVERLAYSIZE 8
LABEL
COLOR 255 255 255
MINDISTANCE 200
TYPE TRUETYPE
FONT verdana_bold
SIZE 11
ANTIALIAS TRUE
POSITION CC
BUFFER 2
END
END
END
END
