[mapserver-users] did something change in reading in empty TAB
files?
Daniel Morissette
dmorissette at mapgears.com
Thu Jul 10 09:01:37 EDT 2008
Bart,
The "Invalid Block Type" message comes from the MITAB driver in
GDAL/OGR. GDAL 1.3.2 is quite old, is there any way you could switch to
a more recent version of GDAL? Based on Jeff's tests this error doesn't
seem to happen with MS 5.0.2/GDAL 1.5.0 ... it may also be that the
problem is a side-effect of something that changed in MapServer (and
would now be fixed in 5.0.x), but the first thing I'd suggest is using a
newer GDAL.
Daniel
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> at least starting Mapserver 4.10 (GDAL 1.3.2) there seems to be a
> problem with reading empty MapInfo TAB files, whereas in the past (4.6
> for sure) this used to work. Is this issue known to someone?
> The error I get is:
> 09-Jul-2008 18:08:23] PHP Warning: [MapServer Error]:
> msOGRFileNextShape(): InitBlockFromData(): Invalid Block Type: got 0
> expected 2
> in
> D:\ms4w\apps\stragisweb\htdocs\common\chameleon\htdocs\common\wrapper\drawmap.php
> on line 533
> An example TAB file can be found here:
> www.osgis.nl/download/mapserver/gemgrens.zip
> Best regards,
> Bart
Daniel Morissette
http://www.mapgears.com/
