[mapserver-users] Reprojection: Maps not lining up
Matthew Pettis
matthew.pettis at gmail.com
Thu Jul 10 17:35:51 EDT 2008
(This is a repost, the other one got no responses).
I am using Openlayers with Mapserver to show a shapefile of roads in MN that
are in epsg:26915 and allowing users to toggle between that and Google Maps
(spherical Mercator projection per
http://spatialreference.org/ref/user/google-projection/). I use mapserv.exe
and a .map file to reproject the MN roads into the Google projection, and
when I toggle between them, the extents *almost* match up. It appears that
the MN roads extent covers a slightly larger area than the Google Maps
extent.
I don't know if this is an OpenLayers or Mapserver question, but I'm
thinking it is a Mapserver one. Can anyone tell me why the extents *almost*
match up? I would think that they would either match up almost exactly (or
at least in a tolerance that I cannot tell by the naked eye), or I would
have messed up my transformations, and it would be completely out of sync.
Is it a function of disparities in the data that I cannot fix, or are there
fine tunings that I can adjust to compensate?
Thanks,
Matt
It is from the wellspring of our despair and the places that we are broken
that we come to repair the world.
-- Murray Waas
