[mapserver-users] gap between layers
Jean-Paul Chiron
jpchiron at gmail.com
Tue Jul 15 10:54:15 EDT 2008
2008/7/15 Frank Warmerdam <warmerdam at pobox.com>:
> Jean-Paul Chiron wrote:
>> Hello,
>> when I've migrate one mapserver application from a server to another,
>> with the same version of software ( mapserver 4.6.1 ), I've a big gap
>> between the base map (which is based on .shp file) et the layers which
>> are based on postgis.
>> The problem cannot came from postgis, because it's the same database
>> between the two servers.
>> I was thinking that it comes from GDAL, but I didn't see anything...
>> Is there anybody have an idear for that problem ?
>> Where can I investigate to find the mistake ?
> Jean-Paul,
> Is there reprojection involved? Datum shifting? Perhaps it relates
> to a different version of PROJ.4 or difficulty finding datum shift files?
> There has been a significant change in the how PROJ.4 decides when a
> change of datum shift should be applied between PROJ 4.5 and 4.6.
> These are angles I'd look into a bit if I were you.
Well done Franck !
There was a mistake on the new server between proj-4.4.9 and proj-4.5.0
It works with proj-4.5.0.
Thank you !
