[mapserver-users] Drawing a Line From A Set Start Point to End
Point
wallacher at innomis
wallacher at innomis.com
Thu Jul 17 04:05:46 EDT 2008
Hi Lena, if tried this code and it works.
$mypoints=array(
array(1,1), // 1. point
array(40,1), // 1. point
array(40,80), // 1. point
array(1,80), // 1. point
$myline=ms_newLineObj();
foreach ($mypoints as $key => $value) {
$myline->addXY($value[0],$value[1]);
//Create the shape object that will be added to the layer
$shape=ms_newShapeObj(MS_SHAPE_LINE);
$shape->add($myline);
$this_layer_tornado->addFeature($shape);
Erik
> Hello,
> I am trying to draw tornado paths on my map that I am creating, but I
> am having a little bit of trouble because now it won't even plot the
> initial point on my map. The following is my code for attempting to
> draw a line from start to finish. If anyone has any helpful
> information, it would be greatly appreciated
> while($row=mysql_fetch_assoc($result)){
> $mypoint=ms_newPointObj();
> $mypoint->setXY($row['lon_td'],$row['lat_td']);
> $myline->add($mypoint);
> $endpoint=ms_newPointObj();
> $endpoint->setXY($row['lon_lift'],$row['lat_lift']);
> $myline->add($endpoint);
> $mypoint->draw($map,$this_layer_tornado,$image,0,'');
> Thank you,
> Lena
> *Lena Olympio*
> mapserver-users at lists.osgeo.org
