[mapserver-users] v5.0.0 - CLASSITEM has double quote in field
value
Mike Saunt
mikesaunt at gmail.com
Fri Jul 18 09:16:56 EDT 2008
Alexandre
Excellent - that works!
FYI - This is why I believe that Open Source can easily prevail even when
people put down the 'many eyes see more bugs' notion. In another life I
worked with / as a partner for a proprietary company (now you can buy
franking machines from the same parent company wink wink nudge nudge) and
you'd never get this response so quickly and also having 'had it from the
horses mouth a.k.a. Developers' that there is an issue and this is the best
way around it.
Thanks so much Alexandre
Kind regards
Mike
2008/7/18 Alexandre Dube <adube at mapgears.com>:
> I've been told by developers that there seems to be a bug when using " " in
> the expression parser...
> You should use a regular expression instead like the following :
> EXPRESSION /^Lane Closure$|^Multi-Way Signals$|^Road Closure$|^Stop\/Go
> Boards$|^Two-Way Signals$/
> See at : http://mapserver.gis.umn.edu/docs/howto/msexpressions
> Mike Saunt wrote:
>> thanks Alexandre but unfortunately it didn't work
>> Do you know if there is a way of forcing MapServer to read out the literal
>> string i.e. sort of like escaping it? in .NET you can say @stringvariable
>> and it will ignore quotes inside etc?
>> Cheers
>> Mike
>> 2008/7/18 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com
>> Hi Mike,
>> I'm not sure about that, but try eq instead of =
>> EXPRESSION ('[TRAFFIC_TYPE]' eq 'Lane Closure' OR ...
>> Best Regards,
>> Alexandre
>> Mike Saunt wrote:
>> Hi All
>> I've got a MapFile that used to work fine in v4.10 but now
>> fails in v5.0
>> Basically the CLASSITEM field has double quote in field value
>> and this is then returning an error - msEvalExpression:
>> Expression parser error. Failed to parse expression
>> The CLASS EXPRESSION looks like this
>> CLASSITEM 'TRAFFIC_TYPE' CLASS
>> EXPRESSION ('[TRAFFIC_TYPE]' = 'Lane Closure' OR
>> '[TRAFFIC_TYPE]' = 'Multi-Way Signals' OR '[TRAFFIC_TYPE]' =
>> 'Road Closure' OR '[TRAFFIC_TYPE]' = 'Stop/Go Boards' OR
>> '[TRAFFIC_TYPE]' = 'Two-Way Signals')
>> STYLE # Severe (RED)
>> SYMBOL 'triangle'
>> SIZE 9
>> COLOR 255 0 0
>> OUTLINECOLOR 0 0 0
>> END
>> END
>> I've tried double quote vs. single quotes in the map file but
>> to no avail
>> Anyone any thoughts?
>> Kind regards
>> Mike
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> -- Alexandre Dubé
>> Mapgears
>> www.mapgears.com <http://www.mapgears.com>
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080718/d966c7fe/attachment.html
