[mapserver-users] Compiling Issues: Ubuntu 8.04 -- libgd and
gdFontCacheSetup
Matthew Pettis
matthew.pettis at gmail.com
Fri Jul 18 19:26:37 EDT 2008
Hi All,
This still fails... below is my configuration parameter setup and the
output of configure are below... any suggestions?
thanks,
matt
=== configure parameters ===
./configure --with-ogr=/usr \
--with-gdal=/usr \
--with-httpd=/usr/sbin/apache2 \
--with-wfsclient \
--with-wmsclient \
--enable-debug \
--with-curl=/usr \
--with-proj=/usr \
--with-threads \
--with-tiff \
--with-libiconv=/usr/local/lib \
--with-jpeg \
--with-freetype=/usr/lib/xorg/modules/fonts/ \
--with-threads \
--with-wcs \
--with-xml2-config=/usr/bin/xml2-config \
--with-gd=/usr \
--with-php=/usr
=== output of configure script ===
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for flex... no
checking for lex... no
checking for yywrap in -lfl... no
checking for yywrap in -ll... no
checking for bison... no
checking for byacc... no
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for exp in -lm... yes
checking for __gxx_personality_v0 in -lstdc++... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
checking for strlcat... no
checking for vsnprintf... yes
MapServer Version from mapserver.h: '5.0.3'
configure: checking where FreeType 2.x is installed...
using libfreetype from -L/usr/lib/xorg/modules/fonts/ -lfreetype
configure: checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs (-DUSE_ZLIB).
configure: checking where PNG is installed...
checking for png_init_io in -lpng... yes
using libpng from system libs.
configure: checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
configure: checking where libXpm is installed...
checking for XpmFreeXpmImage in -lXpm... yes
using libXpm from system libs.
configure: checking where libiconv is installed...
checking for iconv_open in -lc... yes
checking for libiconv_open in -liconv... yes
using libiconv from -L -liconv
libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.16 or higher...
checking for gdFontCacheSetup in -lgd... no
configure: checking whether GD needs libiconv...
configure: error: Could not find gd.h or libgd.a/libgd.so in /usr.
Make sure GD 2.0.16 or higher is compiled before calling configure.
You may also get this error if you didn't specify the appropriate
location for one of GD's dependencies (freetype, libpng, libjpeg or
libiconv).
On Fri, Jul 18, 2008 at 9:04 AM, Matthew Pettis
<matthew.pettis at gmail.com> wrote:
> Replied to your previous one -- I will try again tonight with your
> suggestion and update the list with the results -- Thanks again!
> Matt
> On Fri, Jul 18, 2008 at 8:54 AM, Daniel Morissette
> <dmorissette at mapgears.com> wrote:
>> As I wrote in a previous message, is it possible that you configured using
>> "--with-gd=/usr/lib"? You should use "--with-gd=/usr" only and the configure
>> script should take care of looking in the right subdirectory for each file.
>> Daniel
>> Matthew Pettis wrote:
>>> Hi,
>>> More and different compiling issues from the one I've already
>>> posted... My configure script errors as shown below (truncated because
>>> I believe the most important part is included):
>>> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/lib.
>>> libiconv).
>>> Now, I have libgd version 2.0.35, so this should work... I have gd.h
>>> and libgd.a/libgd.so (the latter are in /usr/lib/). I think it is
>>> choking because of the gdFontCacheSetup. Any idea on how to fix this?
>>> Thanks,
>>> Matt
>> Daniel Morissette
>> http://www.mapgears.com/
> It is from the wellspring of our despair and the places that we are
> broken that we come to repair the world.
> -- Murray Waas
-- Murray Waas
