[mapserver-users] Compiling Issues: Ubuntu 8.04 -- libgd and
gdFontCacheSetup
thomas bonfort
thomas.bonfort at gmail.com
Sat Jul 19 01:28:00 EDT 2008
hi,
have you installed the libgd development packages ?
# apt-get install libgd-dev
thomas
On Sat, Jul 19, 2008 at 1:26 AM, Matthew Pettis
<matthew.pettis at gmail.com> wrote:
> Hi All,
> This still fails... below is my configuration parameter setup and the
> output of configure are below... any suggestions?
> thanks,
> matt
> === configure parameters ===
> ./configure --with-ogr=/usr \
> --with-gdal=/usr \
> --with-httpd=/usr/sbin/apache2 \
> --with-wfsclient \
> --with-wmsclient \
> --enable-debug \
> --with-curl=/usr \
> --with-proj=/usr \
> --with-threads \
> --with-tiff \
> --with-libiconv=/usr/local/lib \
> --with-jpeg \
> --with-freetype=/usr/lib/xorg/modules/fonts/ \
> --with-threads \
> --with-wcs \
> --with-xml2-config=/usr/bin/xml2-config \
> --with-gd=/usr \
> --with-php=/usr
> === output of configure script ===
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for ranlib... ranlib
> checking for flex... no
> checking for lex... no
> checking for yywrap in -lfl... no
> checking for yywrap in -ll... no
> checking for bison... no
> checking for byacc... no
> checking if compiler supports -R... no
> checking if compiler supports -Wl,-rpath,... yes
> checking for exp in -lm... yes
> checking for __gxx_personality_v0 in -lstdc++... yes
> checking how to run the C preprocessor... gcc -E
> checking for egrep... grep -E
> checking for ANSI C header files... yes
> checking for strcasecmp... yes
> checking for strncasecmp... yes
> checking for strdup... yes
> checking for strlcat... no
> checking for vsnprintf... yes
> MapServer Version from mapserver.h: '5.0.3'
> configure: checking where FreeType 2.x is installed...
> using libfreetype from -L/usr/lib/xorg/modules/fonts/ -lfreetype
> configure: checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs (-DUSE_ZLIB).
> configure: checking where PNG is installed...
> checking for png_init_io in -lpng... yes
> using libpng from system libs.
> configure: checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
> using libjpeg from system libs.
> configure: checking where libXpm is installed...
> checking for XpmFreeXpmImage in -lXpm... yes
> using libXpm from system libs.
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... yes
> checking for libiconv_open in -liconv... yes
> using libiconv from -L -liconv
> libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.16 or higher...
> checking for gdFontCacheSetup in -lgd... no
> configure: checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr.
> Make sure GD 2.0.16 or higher is compiled before calling configure.
> You may also get this error if you didn't specify the appropriate
> location for one of GD's dependencies (freetype, libpng, libjpeg or
> libiconv).
> On Fri, Jul 18, 2008 at 9:04 AM, Matthew Pettis
>> Replied to your previous one -- I will try again tonight with your
>> suggestion and update the list with the results -- Thanks again!
>> Matt
>> On Fri, Jul 18, 2008 at 8:54 AM, Daniel Morissette
>> <dmorissette at mapgears.com> wrote:
>>> As I wrote in a previous message, is it possible that you configured using
>>> "--with-gd=/usr/lib"? You should use "--with-gd=/usr" only and the configure
>>> script should take care of looking in the right subdirectory for each file.
>>> Daniel
>>> Matthew Pettis wrote:
>>>> Hi,
>>>> More and different compiling issues from the one I've already
>>>> posted... My configure script errors as shown below (truncated because
>>>> I believe the most important part is included):
>>>> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/lib.
>>>> libiconv).
>>>> Now, I have libgd version 2.0.35, so this should work... I have gd.h
>>>> and libgd.a/libgd.so (the latter are in /usr/lib/). I think it is
>>>> choking because of the gdFontCacheSetup. Any idea on how to fix this?
>>>> Thanks,
>>>> Matt
>>> Daniel Morissette
>>> http://www.mapgears.com/
>> It is from the wellspring of our despair and the places that we are
>> broken that we come to repair the world.
>> -- Murray Waas
> -- Murray Waas
> mapserver-users at lists.osgeo.org
