[mapserver-users] Compiling Issues: Ubuntu 8.04 -- libgd and
gdFontCacheSetup
Matthew Pettis
matthew.pettis at gmail.com
Sat Jul 19 16:46:26 EDT 2008
Hi Guillaume, All,
Guillaume was right, the install is in /usr/local, but when I changed
the configure script to take
--with-gd=/usr/local
I get the same results as before (./configure dump is same as
previously posted). Other ideas?
Thanks,
Matt
On Sat, Jul 19, 2008 at 12:30 PM, Guillaume Sueur
<guillaume.sueur at neogeo-online.net> wrote:
> yes, it would. be you probably didn't install it in /usr like you specify in
> your configure.
> so try with --with-gd=/usr/local instead
> good luck !
> Guillaume
> Matthew Pettis a écrit :
>> Hi,
>> I actually downloaded, unpacked, configure/make/make install'ed from
>> http://www.libgd.org/releases/gd-2.0.35.tar.gz
>> I assume that would be the same thing as your command below?
>> thanks,
>> Matt
>> On Sat, Jul 19, 2008 at 12:28 AM, thomas bonfort
>> <thomas.bonfort at gmail.com> wrote:
>>> hi,
>>> have you installed the libgd development packages ?
>>> # apt-get install libgd-dev
>>> thomas
>>> On Sat, Jul 19, 2008 at 1:26 AM, Matthew Pettis
>>> <matthew.pettis at gmail.com> wrote:
>>>> Hi All,
>>>> This still fails... below is my configuration parameter setup and the
>>>> output of configure are below... any suggestions?
>>>> thanks,
>>>> matt
>>>> === configure parameters ===
>>>> ./configure --with-ogr=/usr \
>>>> --with-gdal=/usr \
>>>> --with-httpd=/usr/sbin/apache2 \
>>>> --with-wfsclient \
>>>> --with-wmsclient \
>>>> --enable-debug \
>>>> --with-curl=/usr \
>>>> --with-proj=/usr \
>>>> --with-threads \
>>>> --with-tiff \
>>>> --with-libiconv=/usr/local/lib \
>>>> --with-jpeg \
>>>> --with-freetype=/usr/lib/xorg/modules/fonts/ \
>>>> --with-threads \
>>>> --with-wcs \
>>>> --with-xml2-config=/usr/bin/xml2-config \
>>>> --with-gd=/usr \
>>>> --with-php=/usr
>>>> === output of configure script ===
>>>> checking for gcc... gcc
>>>> checking for C compiler default output file name... a.out
>>>> checking whether the C compiler works... yes
>>>> checking whether we are cross compiling... no
>>>> checking for suffix of executables...
>>>> checking for suffix of object files... o
>>>> checking whether we are using the GNU C compiler... yes
>>>> checking whether gcc accepts -g... yes
>>>> checking for gcc option to accept ANSI C... none needed
>>>> checking for g++... g++
>>>> checking whether we are using the GNU C++ compiler... yes
>>>> checking whether g++ accepts -g... yes
>>>> checking for ranlib... ranlib
>>>> checking for flex... no
>>>> checking for lex... no
>>>> checking for yywrap in -lfl... no
>>>> checking for yywrap in -ll... no
>>>> checking for bison... no
>>>> checking for byacc... no
>>>> checking if compiler supports -R... no
>>>> checking if compiler supports -Wl,-rpath,... yes
>>>> checking for exp in -lm... yes
>>>> checking for __gxx_personality_v0 in -lstdc++... yes
>>>> checking how to run the C preprocessor... gcc -E
>>>> checking for egrep... grep -E
>>>> checking for ANSI C header files... yes
>>>> checking for strcasecmp... yes
>>>> checking for strncasecmp... yes
>>>> checking for strdup... yes
>>>> checking for strlcat... no
>>>> checking for vsnprintf... yes
>>>> MapServer Version from mapserver.h: '5.0.3'
>>>> configure: checking where FreeType 2.x is installed...
>>>> using libfreetype from -L/usr/lib/xorg/modules/fonts/ -lfreetype
>>>> configure: checking where Zlib is installed...
>>>> checking for zlibVersion in -lz... yes
>>>> using libz from system libs (-DUSE_ZLIB).
>>>> configure: checking where PNG is installed...
>>>> checking for png_init_io in -lpng... yes
>>>> using libpng from system libs.
>>>> configure: checking whether we should include JPEG support...
>>>> checking for jpeg_read_header in -ljpeg... yes
>>>> using libjpeg from system libs.
>>>> configure: checking where libXpm is installed...
>>>> checking for XpmFreeXpmImage in -lXpm... yes
>>>> using libXpm from system libs.
>>>> configure: checking where libiconv is installed...
>>>> checking for iconv_open in -lc... yes
>>>> checking for libiconv_open in -liconv... yes
>>>> using libiconv from -L -liconv
>>>> libiconv found. Enabling internationalization (-DUSE_ICONV)
>>>> configure: checking for GD 2.0.16 or higher...
>>>> checking for gdFontCacheSetup in -lgd... no
>>>> configure: checking whether GD needs libiconv...
>>>> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr.
>>>> Make sure GD 2.0.16 or higher is compiled before calling configure.
>>>> You may also get this error if you didn't specify the appropriate
>>>> location for one of GD's dependencies (freetype, libpng, libjpeg or
>>>> libiconv).
>>>> On Fri, Jul 18, 2008 at 9:04 AM, Matthew Pettis
>>>>> Replied to your previous one -- I will try again tonight with your
>>>>> suggestion and update the list with the results -- Thanks again!
>>>>> Matt
>>>>> On Fri, Jul 18, 2008 at 8:54 AM, Daniel Morissette
>>>>> <dmorissette at mapgears.com> wrote:
>>>>>> As I wrote in a previous message, is it possible that you configured
>>>>>> using
>>>>>> "--with-gd=/usr/lib"? You should use "--with-gd=/usr" only and the
>>>>>> configure
>>>>>> script should take care of looking in the right subdirectory for each
>>>>>> file.
>>>>>> Daniel
>>>>>> Matthew Pettis wrote:
>>>>>>> Hi,
>>>>>>> More and different compiling issues from the one I've already
>>>>>>> posted... My configure script errors as shown below (truncated
>>>>>>> because
>>>>>>> I believe the most important part is included):
>>>>>>> /usr/lib.
>>>>>>> libiconv).
>>>>>>> Now, I have libgd version 2.0.35, so this should work... I have gd.h
>>>>>>> and libgd.a/libgd.so (the latter are in /usr/lib/). I think it is
>>>>>>> choking because of the gdFontCacheSetup. Any idea on how to fix
>>>>>>> this?
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>> Daniel Morissette
>>>>>> http://www.mapgears.com/
>>>>> It is from the wellspring of our despair and the places that we are
>>>>> broken that we come to repair the world.
>>>>> -- Murray Waas
>>>> -- Murray Waas
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
-- Murray Waas
