[mapserver-users] MapServer Version 5.2.0 Source Released
thomas bonfort
thomas.bonfort at gmail.com
Mon Jul 21 13:34:20 EDT 2008
Yes, that patch won't apply on 5.2 as there have been substantial
changes in that code.
You'll have to manually merge it (the logic is the same). The function
you're looking for is msDrawLineSymbolAGG
thomas
On Mon, Jul 21, 2008 at 5:26 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> As far as I know there isn't such a switch. If you could produce the patch we could
> take a look though.
> Steve
>>>> On 7/17/2008 at 7:54 AM, in message
> <E534BE8FE04ADF4FA3C837466F4F35400932A3 at KTWMAIL.ilpcs.com>, "Nolte, Tim"
> <Tim.Nolte at ipcswirelessinc.com> wrote:
>> Is there a built-in facility to turn off anti-aliasing for certain
>> layers when using AGG in this build? I had a patch given to me by
>> someone else on the list that worked with MS 5.0, that patch doesn't
>> work on this build. Thanks.
>> - Tim
>> Timothy J Nolte - tnolte at ilpcs.com
>> Network Planning Engineer
>> iPCS Wireless, Inc.
>> 4717 Broadmoor Ave, Suite G
>> Kentwood, MI 49512
>> Office: 616-656-5163
>> PCS: 616-706-2438
>> Fax: 616-554-6484
>> Web: www.ipcswirelessinc.com
>>> -----Original Message-----
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>>> Steve Lime
>>> Sent: Wednesday, July 16, 2008 9:52 PM
>>> To: mapserver-announce at lists.osgeo.org;
>>> mapserver-dev at lists.osgeo.org; mapserver-users at lists.osgeo.org
>>> Subject: [mapserver-users] MapServer Version 5.2.0 Source Released
>>> Hi all: The MapServer PSC is proud to announce the release of
>>> MapServer version 5.2. The source code is available for download at:
>>> http://mapserver.gis.umn.edu/download/current
>>> Binary distributions will follow shortly. This is a
>>> significant release and users are encouraged to upgrade if
>>> possible. Nearly 200 tickets were closed as part of this
>>> effort. Major feature additions include:
>>> * MS RFC 36: Simplified Template Support for Query Output
>>> * MS RFC 37: Spatial Reference Improvements and Additions
>>> * MS RFC 38: Native Microsoft SQL Server 2008 Support
>>> * MS RFC 41: WCS 1.1.x Support
>>> * MS RFC 42: Support for Cookie Forwarding
>>> * MS RFC 43: Direct Tile Generation for Google Maps API
>>> Full RFC text can be found at:
>>> http://mapserver.gis.umn.edu/development/rfc
>>> Notable enhancements include:
>>> * performance enhancements for large shapefile handling
>>> * performance enhancements for AGG rendering (an order of
>>> magnitude faster in some cases)
>>> * fuzzy label outlines for AGG
>>> * style-level opacity for AGG
>>> * quantization and palette support for PNGs and RGBA modes
>>> * SOS 1.0.0 support
>>> * WFS 1.1.0 support
>>> * proxy and http authentication support for cascaded WMS requests
>>> * pre-clip label point computation (helps in tile generation)
>>> * extent (e.g. shpext, mapext) template tag attribute handling
>>> The full 5.2.0 change log can be found at:
>>> http://trac.osgeo.org/mapserver/browser/tags/rel-5-2-0/mapserv
>>> er/HISTORY.TXT
>>> I would like to thank all the folks that worked hard on this
>>> release, your efforts are greatly appreciated!
>>> Steve
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
