[mapserver-users] More info on DNC problem
Derek Bain
beartreeyoga at yahoo.co.uk
Tue Jul 22 11:34:50 EDT 2008
Hi
I used the command
ogrinfo -ro -summary gltp:/vrf/c:/ms4w/apps/some_folder/data/DNC13/H1316030
on a folder containing digital nautical charts to get the listing below. I then created the map file using the info for layer 14 ( hydarea at hyd(*)_area (Polygon) ) and using the extents from orginfo with hydarea at hyd(*)_area as its parameter. I tried testing the map file using shp2img but keep getting the error "Projection library error. No such file or directory" From what I can find from web searching etc, this error description covers a lot of different errors.
From what i can see from hydarea at hyd, hyd is a subfolder of H1316030 i.e C:\ms4w\apps\some_folder\data\DNC13\H1316030\HYD and hydarea is file inside that folder with the extension .AFT
Can anyone offer any help
Thanks
Derek
Map File---->
# Digital Nautical Maps for H1316030
# (14: hydarea at hyd(*)_area (Polygon))
LAYER
NAME "hydarea_hyd_area"
TYPE POLYGON
CONNECTIONTYPE OGR
# MapServer Layer = ogrinfo layer - 1 i.e. 14-1 = 13
CONNECTION "C:/ms4w/Apps/some_folder/data/DNC13/H1316030,13" # 14: hydarea at hyd(*)_area (Polygon)
STATUS ON
PROJECTION
"init=epsg:4326"
END # End Projection
METADATA
"wms_title" "hydarea at hyd(*)_area"
"wms_abstract" "hydarea at hyd(*)_area abstract goes here ...."
"wms_srs" "epsg:4326"
"wms_name" "hydarea"
# [minx_left] [miny_bottom] [maxx_right] [maxy_top]
"wms_extent" "-118.646797 32.933327 -118.475853 33.066673"
"wms_onlineresource" "http://localhost:8082/cgi-bin/mapserv.exe?map=C:/ms4w/apps/some_folder/dnc2.map"
END # End Metadata
CLASS
NAME "hydarea"
COLOR 255 0 0
END # End Class
END # End Layer
ORGINFO output----------->
Layer name: hydarea at hyd(*)_area
Geometry: Polygon
Feature Count: 63
Extent: (-118.646797, 32.933327) - (-118.475853, 33.066673)
Layer SRS WKT:
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4269"]]
f_code: String (5.0)
acc: Integer (5.0)
cvh: Real (15.6)
cvl: Real (15.6)
tile_id: Integer (5.0)
fac_id: Integer (10.0)
1: buildnga at cul(*)_area (Polygon)
2: transl at cul(*)_line (Line String)
3: buildngp at cul(*)_point (Point)
4: commp at cul(*)_point (Point)
5: industp at cul(*)_point (Point)
6: ecrarea at ecr(*)_area (Polygon)
7: foreshoa at ecr(*)_area (Polygon)
8: coastl at ecr(*)_line (Line String)
9: foreshol at ecr(*)_line (Line String)
10: islandp at ecr(*)_point (Point)
11: ecrtext at ecr(*)_text (Point)
12: envarea at env(*)_area (Polygon)
13: tidep at env(*)_point (Point)
15: hydline at hyd(*)_line (Line String)
16: botcharp at hyd(*)_point (Point)
17: soundp at hyd(*)_point (Point)
18: embanka at lcr(*)_area (Polygon)
19: lcrline at lcr(*)_line (Line String)
20: limbndya at lim(*)_area (Polygon)
21: limbndya at lim(*)_area (Polygon)
22: distl at lim(*)_line (Line String)
23: distl at lim(*)_line (Line String)
24: limbndyl at lim(*)_line (Line String)
25: limbndyl at lim(*)_line (Line String)
26: routel at lim(*)_line (Line String)
27: routel at lim(*)_line (Line String)
28: limbndyp at lim(*)_point (Point)
29: leadingl at nav(*)_line (Line String)
30: buoybcnp at nav(*)_point (Point)
31: lightsp at nav(*)_point (Point)
32: dangera at obs(*)_area (Polygon)
33: hazarda at obs(*)_area (Polygon)
34: obstruca at obs(*)_area (Polygon)
35: reefa at obs(*)_area (Polygon)
36: hazardl at obs(*)_line (Line String)
37: dangerp at obs(*)_point (Point)
38: hazardp at obs(*)_point (Point)
39: obstrucp at obs(*)_point (Point)
40: ruinsp at obs(*)_point (Point)
41: piera at por(*)_area (Polygon)
42: structra at por(*)_area (Polygon)
43: pierl at por(*)_line (Line String)
44: structrl at por(*)_line (Line String)
45: relline at rel(*)_line (Line String)
46: relpoint at rel(*)_point (Point)
47: dqyarea at dqy(*)_area (Polygon)
48: tileref at tileref(*)_area (Polygon)
49: libref at libref(*)_line (Line String)
__________________________________________________________
Not happy with your email address?.
Get the one you really want - millions of new email addresses available now at Yahoo! http://uk.docs.yahoo.com/ymail/new.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080722/7cc2e1e5/attachment.html
