[mapserver-users] More info on DCN problem and possible
gdal/ogrproblem
Fawcett, David
David.Fawcett at state.mn.us
Wed Jul 23 09:20:30 EDT 2008
It is possible that the ogr in your FWTools installation supports
additional formats that the ogr from MS4W doesn't.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Derek Bain
Sent: Wednesday, July 23, 2008 8:16 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] More info on DCN problem and possible
gdal/ogrproblem
Hi
If I run the command
ogrinfo -ro -summary
gltp:/vrf/c:/ms4w/apps/seetrack_missions/data/DNC13/H1316030
"hydarea at hyd(*)_area"
from C:\Program Files\FWTools2.2.0\bin i get
INFO: Open of
`gltp:/vrf/c:/ms4w/apps/seetrack_missions/data/DNC13/H1316030'
using driver `OGDI' successful.
Layer name: hydarea at hyd(*)_area
Geometry: Polygon
<snip>
HOWEVER, if I run it from C:\ms4w\tools\gdal-ogr i get
FAILURE:
Unable to open datasource
1316030' with the following drivers.
ESRI Shapefile
<snip>
OGDI
<snip>
I can change the path in SetEnv.bat but this only works for the
command line. MapServer still seems to use the files in
C:\ms4w\tools\gdal-ogr.
I copied the existing contents of the C:\ms4w\tools\gdal-ogr
folder to a temp folder and then copied the contents of C:\Program
Files\FWTools2.2.0\bin to gdal-org folder. gdalinfo now works but the
shp2img still fails with a "... OGR error. Open failed for OGR
connection .... " error message. Also I noticed that ogr2ogr pops up a
windows message box informing me that ogr2ogr.exe is not a valid Win32
application
Has anyone had similar problems, understands what is happening
or has any thoughts
thanks
Derek
Not happy with your email address?
Get the one you really want
<http://uk.docs.yahoo.com/ymail/new.html> - millions of new email
addresses available now at Yahoo!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080723/d2eb810a/attachment.html
