[mapserver-users] WFS GetFeature with PostGIS database : the
PostGIS request is not
well formated (with string fields that contains only numbers)
"SAEZ Laurent - CETE Méditerr./DI/ETER"
Laurent.Saez at developpement-durable.gouv.fr
Thu Jul 24 10:18:44 EDT 2008
Hi List,
I have a PostGIS database.
I have a point table representing plots.
I have to select a plot using several fields :
* num_dep (string) : departement code,
* nom_com (string) : city name,
* section (string) : section number,
* numero (string) : plot number.
I use MapServer 4.99 and Postgersql 8.1.
All my fields are strings.
Result of DescribeFeatureType request :
<complexType name="bdparcellaire_numeroType">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element name="geometry" type="gml:PointPropertyType"
minOccurs="0" maxOccurs="1"/>
<element name="code_dep" type="string"/>
<element name="nom_com" type="string"/>
<element name="section" type="string"/>
<element name="numero" type="string"/>
<element name="gid" type="string"/>
<element name="oid" type="string"/>
</sequence>
</extension>
</complexContent>
</complexType>
When I do a WFS GetFeature request, mapserver doesn't format correctly
strings fields that contains only numbers.
Example : (to select the plot where num_dep='66' and nom_com='Baixas'
and section='0A' and numero='2651')
http://mapserver_i2.cete-mediterranee.i2/maps/mapserv?map=%2Fdata%2Fcarto%2Fref%2Fbdparcellaire%2Fbdparcellaire_2007_iso.map&=&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=bdparcellaire_numero&FILTER=%28%3CFilter%3E%3CAnd%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3Ecode_dep%3C%2FPropertyName%3E%3CLiteral%3E66%3C%2FLiteral%3E%3C%2FPropertyIsEqualTo%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3Enom_com%3C%2FPropertyName%3E%3CLiteral%3EBaixas%3C%2FLiteral%3E%3C%2FPropertyIsEqualTo%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3Esection%3C%2FPropertyName%3E%3CLiteral%3E0A%3C%2FLiteral%3E%3C%2FPropertyIsEqualTo%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3Enumero%3C%2FPropertyName%3E%3CLiteral%3E2651%3C%2FLiteral%3E%3C%2FPropertyIsEqualTo%3E%3C%2FAnd%3E%3C%2FFilter%3E%29
For human people :
map=/data/carto/ref/bdparcellaire/bdparcellaire_2007_iso.map&=
&SERVICE=WFS
&VERSION=1.0.0
&REQUEST=GetFeature
&FILTER=(
<Filter>
<And>
<PropertyIsEqualTo>
<PropertyName>code_dep</PropertyName>
<Literal>66</Literal>
</PropertyIsEqualTo>
<PropertyIsEqualTo>
<PropertyName>nom_com</PropertyName>
<Literal>Baixas</Literal>
<PropertyIsEqualTo>
<PropertyName>section</PropertyName>
<Literal>0A</Literal>
<PropertyIsEqualTo>
<PropertyName>numero</PropertyName>
<Literal>2651</Literal>
</And>
</Filter>)
MapServer sends this instruction to PostGIS :
LOG: instruction : DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),oid::text from
(select code_dep, nom_com, section, numero, gid, the_geom, oid FROM
localisant) as foo WHERE ( (code_dep= 66) And ( (nom_com= 'Baixas')
And ( (section= '0A') And (numero= 2651) ) ) ) and (the_geom &&
setSRID( 'BOX3D(47650 1620400,1197850 2677450)'::BOX3D,27582) )
We can see that code_dep and numero are not quoted. It's not a problem
in this example, but when I search the plot with the numero=0256, search
returned no results. The plot exists ! The right request in PostGIS
returns the plot.
It seems that not '0256' is search but 256.
Is it a bug ? I think so !
For me it's very very very very disturbing.
I can't use mapserver as a WFS server to select plot !
I hope someone could help me !
Regards
Laurent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080724/8046a0dd/attachment.html
