[mapserver-users] 24 bit PNG transparent symbols
Ben Brehmer
bbrehmer at refractions.net
Wed Jul 23 15:18:26 EDT 2008
Hi List,
I've been trying to get 24 bit PNG symbols to be transparent.
I've tried both GD and AGG output. I've tried --with-experimental-png.
I've tried editing the symbol in photoshop to be transparent. Basically
fooled around with all the different output format options. I've tried
both RGB and RGBA png images.
8 bit PNG symbols work just fine. But the 24 bit symbols always have a
white and non-transparent background (see attached image).
Is there any other mapfile configurations I can try before I convert all
of my 24 bit images to 8 bit?
Or maybe this is a known bug?
Thanks,
Ben
I'm using:
MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
(also tried Mapserver 5.2 with SUPPORTS=RGBA_PNG )
The mapfile:
MAP
IMAGETYPE "aggpng24"
OUTPUTFORMAT
TRANSPARENT ON
NAME 'aggpng24'
DRIVER "AGG/PNG"
MIMETYPE "image/png mode=24bit"
EXTENSION "png"
IMAGEMODE RGBA #also tried RGB for rgb png images
#NAME "gdpng24"
#DRIVER "GD/PNG"
#MIMETYPE "image/png"
#EXTENSION "png"
#IMAGEMODE RGB #RGBA
END
LAYER
CLASS
STYLE
SYMBOL "../../htdocs/images/markers/blue_star_32.png"
END
END
END
gdalinfo output:
Driver: PNG/Portable Network Graphics
Size is 32, 32
Coordinate System is `'
Metadata:
Software=Adobe ImageReady
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 32.0)
Upper Right ( 32.0, 0.0)
Lower Right ( 32.0, 32.0)
Center ( 16.0, 16.0)
Band 1 Block=32x1 Type=Byte, ColorInterp=Red
Band 2 Block=32x1 Type=Byte, ColorInterp=Green
Band 3 Block=32x1 Type=Byte, ColorInterp=Blue
Band 4 Block=32x1 Type=Byte, ColorInterp=Alpha
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080723/10e930b3/mapserv5-0001.png
