[mapserver-users] Re: mapscript querybypoint on tiled raster layers?
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Tue Jul 29 13:44:28 EDT 2008
Ok...I figured out the problem pretty much right after I clicked send on
that last message. I had generated my tile index.shp with relative
paths for the LOCATION field (i.e., relative to the shp file). I just
regenerated it with absolute path names, and it the query function works
fine.
So would this be a known bug of any sort, or is it just bad practice to
use relative filenames with MapServer?
Regards,
Mike
Mike Leahy wrote:
> Hello list,
> I'm sure this one has come up before, but I can't seem to figure out
> what I need to do. I have some tiled raster layers that I've got in a
> mapfile that is being used for generating ka-map tiles. I'm trying to
> query the values on these layer using the queryByPoint function in
> php_mapscript. I have a generic identify function that returns results
> for any of my vector layers, and for non-tiled raster layers - just not
> for the tiled raster layers. Is it possible to query tiled raster
> layers? If so, can someone spot what I'm doing wrong below?
> The tiled-raster layers in the mapfile generally look like this:
> LAYER
> NAME "Tiled Raster"
> GROUP "Tiled Raster"
> STATUS ON
> TYPE RASTER
> TILEINDEX "/data/index.shp"
> TILEITEM "LOCATION"
> METADATA
> "imageformat" "AGG_JPEG"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> And here is the function in PHP:
> public function Identify($oMap,$layer,$x,$y,$cellSize)
> $oLayer = $oMap->getLayerByName($layer);
> if (in_array($oLayer->type,
> array(MS_LAYER_POINT,MS_LAYER_LINE,MS_LAYER_POLYGON)))
> $oLayer->set("toleranceunits",$oMap->units);
> $oLayer->set("tolerance",$cellSize*3);
> else
> $oLayer->set("tolerance",0);
> $oLayer->set("template","dummy.html");
> $oQPoint = ms_newPointObj();
> $oQPoint->setXY($x,$y);
> $aResults = array();
> if (@$oLayer->queryByPoint($oQPoint,MS_MULTIPLE,$oLayer->tolerance) ==
> MS_SUCCESS)
> $oLayer->open();
> $nResults = $oLayer->getNumResults();
> for ($i=0;$i<$nResults;$i++)
> $oResult = $oLayer->getResult($i);
> $oShape = $oLayer->getShape($oResult->tileindex,
> $oResult->shapeindex);
> $aResults[] = array($oResult,$oShape);
> return $aResults;
> Thanks in advance for any help,
> Mike
