[mapserver-users] Output image resolution - explanation needed
Dejan.Gambin at pula.hr
Thu Jul 31 05:15:47 EDT 2008
Thanks, you helped me a lot
In my example, I have printed an area of aproximately 1km wide on an A4
Landscape that is 29,7cm wide, so 1inch is about 85.5m. So that should be
the reason? :-)
regards, dejan
"Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi> wrote on 31.07.2008 11:00:15:
> Hi,
> What are the dimensions of the image you have captured in real world
> utits? Your original aerial images have half a metre pixel size.
> It mean that at 300 dpi one original image pixel corresponds with
> one pixel at paper if square inch on your printout is presenting
> exactly 150 by 150 meters in nature. That is the maximum quality
> you can achieve. If square inch on paper equals to 75 by 75 meters
> the maximum quolity is achieved already at 150 dpi. Multiplicating
> original image pixels for printing cannot improve the quality. But
> if you have zoomed out so far that creating output image means
> downsampling the original imagery you should see the differense.
> So, if your 2150x1111 low resolution image is covering a
> considerably larger area than 1075x555 meters in real world it
> should look better when downloaded at 300 dpi with 4300x2222 pixels.
> -Jukka Rahkonen-
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] Puolesta Dejan.Gambin at pula.hr
> Lähetetty: 31. heinäkuuta 2008 9:32
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Output image resolution - explanation needed
> Thanks Steve
> I still (unfortunatelly) don't understand why I am getting the "same
> quality" image on the paper with the first and second print (the
> second image has twice more pixels). Is it because of the input
> image itself? To be specific - the raster input is aerial image that
> gdalinfor reports as:
> Driver: GTiff/GeoTIFF
> Files: 5C14-05-DOF.tif
> Size is 4500, 6000
> Coordinate System is `'
> Origin = (5419000.154658853100000,4964998.794652804700000)
> Pixel Size = (0.499829146050620,-0.499829146050620)
> Corner Coordinates:
> Upper Left ( 5419000.155, 4964998.795)
> Lower Left ( 5419000.155, 4961999.820)
> Upper Right ( 5421249.386, 4964998.795)
> Lower Right ( 5421249.386, 4961999.820)
> Center ( 5420124.770, 4963499.307)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
> Overviews: 2250x3000, 1125x1500, 563x750, 282x375
> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
> regards, dejan
> "Steve Lime" <Steve.Lime at dnr.state.mn.us> wrote on 30.07.2008 21:13:55:
> > Resolution in MapServer-speak is referring to the resolution of the
> > output device a map
> > will be displayed on. The value is used for scale computations and
> > nothing else. It does not
> > affect the size (in pixels) of MapServer. Scale values do impact the
> > size at which features
> > and text are rendered IF scaling (via SYMBOLSCALE) is turned on.
> > Higher quality output is
> > usually a matter of having more pixels to print, however you usually
> > want larger features
> > too which is where the resolution parameter combined with scaling can
help.
> > Steve
> > >>> On 7/30/2008 at 2:21 AM, in message
> > <OF8A10F31F.0E3F1C94-ONC1257496.0026AB23-C1257496.00286464 at pula.hr>,
> > <Dejan.Gambin at pula.hr> wrote:
> > > Hi,
> > > I am trying to download a high resolution image and print it on
> a paper. I
> > > am using p.mapper and its download function that enables downloading
the
> > > map image on different resolutions.
> > > I have turned on my raster layer (ortophoto image). I have
> zoomed in to an
> > > area of interest. I have downloaded the map twice - with a
resolution of
> > > 150 and 300. The image is shown i a new page/tab (firefox). I right
click
> > > on the image and save it as a png (also tried with a jpeg) file.Now,
the
> > > first file is 2150x1111 pixels, 120 dpi vertical and horizontal
> resolution
> > > (right click on a file, properties, summary, what does it mean?),
the
> > > second file is 4300x2222 pixels, 120 dpi vertical and horizontal
> > > resolution. Seems ok. The second image is "doubled" in pixel size.
> > > Now, when I try to print this image on A4 paper, using 300dpi, the
images
> > > are the same, there is no "better quality" in second image.
> > > I have just finshed reading the Mapserver thread on "Change image
> > > resolution in mapfile". Several limitations are mentioned there -
max.
> > > image size supported by Mapserver, "resolution" value/tag embedded
in
> > > output format, etc. Can it be related to my problem? Or is it maybe
that
> > > software I am using to print this image doesn't "use" this extra
pixels?
> > > Or I am just missing some basic stuff I need to know :-(
> > > thanks very much on any explanation
> > > regards, dejan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080731/b87e4dee/attachment-0001.html
