[MAPSERVER-USERS] Accessing GDAL raster in MapServer
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun Jun 1 20:32:46 EDT 2008
hmm. I would do the following for testing:
- remove all projection objects
- remove MAXSIZE and RESOLUTION (in case they are causing trouble)
- use gdalinfo commandline utility to get the exact extents of the
image (and to make sure your image can be read by your GDAL version)
- make sure the UNITS value is set to the correct value
- use the shp2img commandline utility for testing
--jeff
On 29-May-08, at 6:33 AM, Pål Kristensen wrote:
> Hi!
> I'm trying to serve some CADRG (A.toc) data through MapServer, but I'm
> obviously doing something wrong because all I get is some error
> messages in
> the logfile. I'm currently using the latest MS4W release.
> This is how the mapfile looks like:
> MAP
> NAME "Rendertest"
> STATUS ON
> SIZE 800 500
> DEBUG 4
> #IMAGETYPE PNG
> #IMAGECOLOR 255 255 255
> #SYMBOLSET "c:/ms4w/sym/symbols/SKsym.sym"
> #FONTSET "c:/ms4w/sym/skfonts/font.list"
> EXTENT -1 53 53 68
> SHAPEPATH "E:/RPF_test/"
> UNITS dd
> MAXSIZE 2048
> RESOLUTION 96
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "ows_schemas_location" "http://schemas.opengeospatial.net"
> "ows_accessconstraints" "Copyright Statens kartverk 2007"
> "wms_srs" "EPSG:4326 EPSG:27391 EPSG:27392 EPSG:27393
> EPSG:27394 EPSG:27395 EPSG:27396 EPSG:27397 EPSG:27398 EPSG:3034
> EPSG:32635
> EPSG:32633 EPSG:32634 EPSG:32631 EPSG:32636 EPSG:32632"
> "ows_exceptions_format" "application/vnd.ogc.se_xml"
> END
> END
> LAYER
> NAME "Test"
> DEBUG 4
> STATUS ON
> DATA "rpf/a.toc"
> TYPE RASTER
> #MINSCALE 3000000
> #PROCESSING "RESAMPLE=AVERAGE"
> #PROCESSING "RESAMPLE=BILINEAR"
> #PROCESSING "RPFTOC_FORCE_RGBA=TRUE"
> METADATA
> "wms_title" "Test"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> END
> And this is the error message:
> [Thu May 29 12:11:41 2008].641000 CGI Request 1 on process 1516
> [Thu May 29 12:11:41 2008].688000 msDrawRasterLayerLow(Test):
> entering.
> [Thu May 29 12:11:42 2008].125000 msResampleGDALToMap in effect:
> cellsize =
> 0.053997
> [Thu May 29 12:11:42 2008].125000 msDrawGDAL(Test): using
> RAW_WINDOW=805 0
> 95841 47616
> [Thu May 29 12:11:42 2008].125000 msDrawGDAL(): red,green,blue,alpha
> bands =
> 1,0,0,0
> [Thu May 29 12:11:42 2008].125000 msDrawMap(): Image handling error.
> Failed
> to draw layer named 'Test'.
> [Thu May 29 12:11:42 2008].125000 msFreeMap(): freeing map at 01535F40
> I would really appreciate any help on this issue?
> Regards,
> Pål Kristensen
> View this message in context: http://www.nabble.com/Accessing-GDAL-raster-in-MapServer-tp17532414p17532414.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
