[mapserver-users] Anit-alias Lines?
Jeshua Lacock
jeshua at openosx.com
Mon Jun 2 16:22:54 EDT 2008
Greetings,
(thanks James Léveillé - your advice worked perfectly!)
I was wondering how to produce anti-aliased lines. I tried using the
'ANTIALIAS true' statement with the style for the line, and I also
tried using the AGG renderer (mapserver was compiled with AGG), but my
lines still do not appear anti-aliased.
Here is an example of my output:
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080602/abc79240/line-example-0001.png
And the corresponding sections of my .map file:
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
LAYER
CONNECTIONTYPE postgis
NAME "roads"
CONNECTION "user=postgres dbname=ca_hwy host=localhost"
DATA "the_geom FROM (SELECT roads.oid AS oid, roads.the_geom AS
the_geom, roads.fename AS fename FROM roads) AS named_roads USING
UNIQUE oid USING SRID=-1"
STATUS ON
TYPE LINE
LABELITEM fename
CLASS
STYLE
COLOR 100 100 100
WIDTH 4
ANTIALIAS TRUE
END
END
END
(I removed the label section to abbreviate)
Can anyone tell me what I am doing wrong or if that is the best I can
make it look?
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
