[mapserver-users] Making mapserver into a WMS
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jun 4 09:01:55 EDT 2008
I believe everything is OK. Try saving the file mapserv.exe on your disk and open it with text editor. It is just that WMS standard gives such a MIME type for GetCapabilities response that it is not often recognised as XML.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Matthew Pettis
> Lähetetty: 4. kesäkuuta 2008 15:56
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Making mapserver into a WMS
> Hi,
> I'm trying to test ms4w as a WMS for use with OpenLayers.
> Went through the tutorial at:
> http://mapserver.gis.umn.edu/docs/howto/wms_server/#setup-a-ma
> pfile-for-your-wms
> I created a simple mapfile according to the specs (I think).
> It is after the '===========' delimiter. I called it with
> the following
> url:
> http://localhost/cgi-bin/mapserv.exe?map=C:\ms4w\Apache\htdocs
> \tmp\map.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
> and it asked me to download the mapserv.exe application. Not
> what i expect. I'm pretty sure everything else is in order,
> because when I
> call:
> \tmp\map.map&mode=map
> I get the expected map in my browser.
> Any ideas what is wrong or how I am screwing up the incantation?
> Thanks,
> Matt
> MAP
> # Map attributes
> IMAGETYPE PNG
> EXTENT 184056.505 4809728.25 767381.245 5478975.75
> SIZE 660 495
> IMAGECOLOR 255 255 255
> FONTSET "C:/ms4w/Apache/htdocs/fonts/fonts.list"
> PROJECTION
> "init=epsg:26915"
> END
> # Web settings
> WEB
> IMAGEPATH "C:/ms4w/Apache/htdocs/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wms_title" "WMS Demo Server"
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
> END
> END
> # State
> # Background shows through missing precincts to show
> where no votes will be coming from
> LAYER
> NAME "state"
> METADATA
> "wms_title" "state"
> END
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres dbname=gisvote password=postgres"
> DATA "the_geom from shp_state"
> STATUS default
> TYPE polygon
> CLASS
> NAME "state"
> COLOR 200 200 200
> END
> END # Layer state
> END
