[mapserver-users] Making mapserver into a WMS
Matthew Pettis
matthew.pettis at gmail.com
Wed Jun 4 19:11:33 EDT 2008
Thanks Jeff and Robert,
I'll check on those add-ons. My driving reason in turning this into a
WMS is so I can test out OpenLayers.
Thanks again for the responses,
Matt
On Wed, Jun 4, 2008 at 4:24 PM, Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> Matt,
> Since you are using MS4W you might also want to check out the following ms4w
> add-on packages:
> 1) MapServer OGC Web Services Workshop
> 2) GMap75 PHP/MapScript Sample Application (the localhost page shows locally
> served WMS URLs)
> --jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 4-Jun-08, at 8:55 AM, Matthew Pettis wrote:
>> Hi,
>> I'm trying to test ms4w as a WMS for use with OpenLayers. Went
>> through the tutorial at:
>> http://mapserver.gis.umn.edu/docs/howto/wms_server/#setup-a-mapfile-for-your-wms
>> I created a simple mapfile according to the specs (I think). It is
>> after the '===========' delimiter. I called it with the following
>> url:
>> http://localhost/cgi-bin/mapserv.exe?map=C:\ms4w\Apache\htdocs\tmp\map.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
>> and it asked me to download the mapserv.exe application. Not what i
>> expect. I'm pretty sure everything else is in order, because when I
>> call:
>> http://localhost/cgi-bin/mapserv.exe?map=C:\ms4w\Apache\htdocs\tmp\map.map&mode=map
>> I get the expected map in my browser.
>> Any ideas what is wrong or how I am screwing up the incantation?
>> Thanks,
>> Matt
>> MAP
>> # Map attributes
>> IMAGETYPE PNG
>> EXTENT 184056.505 4809728.25 767381.245 5478975.75
>> SIZE 660 495
>> IMAGECOLOR 255 255 255
>> FONTSET "C:/ms4w/Apache/htdocs/fonts/fonts.list"
>> PROJECTION
>> "init=epsg:26915"
>> END
>> # Web settings
>> WEB
>> IMAGEPATH "C:/ms4w/Apache/htdocs/tmp/"
>> IMAGEURL "/tmp/"
>> METADATA
>> "wms_title" "WMS Demo Server"
>> "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
>> END
>> END
>> # State
>> # Background shows through missing precincts to show where no
>> votes will be coming from
>> LAYER
>> NAME "state"
>> METADATA
>> "wms_title" "state"
>> END
>> CONNECTIONTYPE postgis
>> CONNECTION "user=postgres dbname=gisvote password=postgres"
>> DATA "the_geom from shp_state"
>> STATUS default
>> TYPE polygon
>> CLASS
>> NAME "state"
>> COLOR 200 200 200
>> END
>> END # Layer state
>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
It is from the wellspring of our despair and the places that we are
broken that we come to repair the world.
-- Murray Waas
