[MAPSERVER-USERS] Mapserver on Solaris 2.10
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Thu Jun 5 08:14:11 EDT 2008
I can safely say that I have successfully compiled MapServer 5.x on
both. We are currently running a production MapServer on Solaris 10 x86.
I'm attaching my build guide for Solaris.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Faldor
Sent: Thursday, June 05, 2008 6:00 AM
To: mapserver-users at lists.osgeo.org
Subject: [MAPSERVER-USERS] Mapserver on Solaris 2.10
Hi all,
I have to ensure that Mapserver can be built and run on Solaris 2.10 and
2.8
Do you know of any issues concerning those versions ?
Regards,
Faldor
View this message in context:
http://www.nabble.com/Mapserver-on-Solaris-2.10-tp17666380p17666380.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Solaris MapServer Build
Install libtool (v1.5.24)
pkgadd -d libtool-1.5.24-sol10-x86-local
ln -s /usr/bin/echo /usr/local/bin/echo
Install binutils (v2.17)
pkgadd -d binutils-2.17-sol10-x86-local
The following files are already installed on the system and are being
used by another package:
/usr/local/info/standards.info
/usr/local/lib/libiberty.a
Do you want to install these conflicting files [y,n,?,q] n
Do you want to continue with the installation of <SMCbinut> [y,n,?] y
Install automake (v1.10)
pkgadd -d automake-1.10-sol10-x86-local
Install GNUmake (v3.81)
pkgadd -d make-3.81-sol10-x86-local
Install expat
pkgadd -d
Install PNG
pkgadd -d
Install fontconfig
pkgadd -d
Install FreeType
pkgadd -d
Install GD
pkgadd -d
Install XML2
pkgadd -d
Install LibTIFF (v3.8.2)
pkgadd -d tiff-3.8.2-sol10-x86-local
Install libXpm (v3.4k)
pkgadd -d xpm-3.4k-sol10-intel-local
Install CURL
pkgadd -d curl-7.17.0-sol10-x86-local
Install FastCGI library(2.4.1) & module(2.4.2)
./configure
make
make install
Rebuild Apache (2.2.3) & Install FastCGI module(2.4.2)
1. Copy or move the mod_fastcgi distribution directory to
<apache_src_dir>/modules/fastcgi.
2. Configure Apache
./configure --prefix=/usr/local/apache --with-mpm=prefork --enable-so \
--enable-ssl --with-ssl=/usr/local/ssl --enable-auth-anon --enable-auth-dbm \
--enable-auth-digest --enable-file-cache --enable-charset-lite --enable-cache \
--enable-disk-cache --enable-mem-cache --enable-deflate --enable-mime \
--enable-mime-magic --enable-cern-meta --enable-expires --enable-headers \
--enable-usertrack --enable-unique-id --enable-version --enable-info \
--enable-vhost-alias --enable-speling --enable-rewrite --enable-env \
--enable-log-config --enable-cgi --enable-alias
3. Rebuild and reinstall Apache.
make
make install
4. Install FastCGI module
cp Makefile.AP2 Makefile
make top_dir=/usr/local/apache
make install
vi /usr/local/apache/conf/httpd.conf
Add: LoadModule fastcgi_module modules/mod_fastcgi.so
Add: AddHandler fastcgi-script fcgi
Add:
<IfModule mod_fastcgi.c>
FastCgiConfig -appConnTimeout 60 -idle-timeout 60 -init-start-delay 1 -minProcesses 2 -maxClassProcesses 20 -startDelay 5
</IfModule>
Add to cgi-bin Location:
SetHandler fastcgi-script
5. Stop and start the server.
apachectl stop
apachectl start
Compile PHP (v5.2.3)
./configure --prefix=/usr/local/php --with-zlib --with-gd --with-freetype-dir=/usr/local \
--enable-gd-native-ttf --with-jpeg-dir=/usr/local/lib --with-png-dir=/usr/local/lib --with-oci8 --enable-ftp --with-curl \
--enable-dbase --enable-soap --enable-force-cgi-redirect --enable-discard-path \
--with-apxs2=/usr/local/apache/bin/apxs
make
make install
install -u root -g root -m 755 -f /export/home/www/cgi-bin sapi/cgi/php-cgi
./libtool --finish /tmp/php-5.2.3/libs
cp php.ini-dist /usr/local/php/lib/php.ini
Add:
AddType application/x-httpd-php .php3
AddType application/x-httpd-php .phtml
### Action application/x-httpd-php /cgi-bin/php-cgi
apachectl stop
apachectl start
Install Proj.4 (v4.5.0)
./configure
make
make install
install updated projections
cd /usr/local/share/proj
mv epsg epsg.bak
unzip proj4-epsg-with-42xxx-and-esri.zip
add to /etc/profile
export ..... PROJ_LIB
PROJ_LIB=/usr/local/share/proj
Install LibGeoTIFF (v1.2.4)
./configure
make
make install
Install GEOS (v2.2.3)
./configure prefix=/usr/local
make
make install
Install OGDI (v3.1.5)
TOPDIR=/tmp/ogdi-3.1.5; export TOPDIR
TARGET=solaris; export TARGET
./configure --with-proj=/usr/local --with-zlib=/usr/local --with-expat=/usr/local
make
make install
Install GDAL (v1.4.2)
./configure --with-geotiff=internal --with-gif=internal --with-jpeg=internal --without-ogdi --with-oci=yes
make
make install
Install shapelib (v1.2.10)
vi Makefile
Add CC = gcc, before CFLAGS
make
vi makeshape.sh
Add "./" before each command execution
make test
Two test should complete successfully
Copy binaries to /usr/local/bin
cp dbfadd /usr/local/bin
cp dbfcreate /usr/local/bin
cp dbfdump /usr/local/bin
cp shpadd /usr/local/bin
cp shpcreate /usr/local/bin
cp shpdump /usr/local/bin
cp shprewind /usr/local/bin
cp shptest /usr/local/bin
cd contrib
vi Makefile
make
vi tests/shpproj.sh
change "dbfcreate test -s 30 fd" to "dbfcreate test -s fd 30"
make check (success...)
cp dbfcat /usr/local/bin
cp dbfinfo /usr/local/bin
cp shpcat /usr/local/bin
cp shpcentrd /usr/local/bin
cp shpdata /usr/local/bin
cp shpdxf /usr/local/bin
cp shpfix /usr/local/bin
cp shpinfo /usr/local/bin
cp shpproj /usr/local/bin
cp shpwkb /usr/local/bin
Install agg
untar/ungzip agg to /usr/local
vi Makefile.in.SunOS
Change:
CXX = CC
To:
CXX = g++
Change:
C = cc
To:
C = gcc
Change:
LIB = CC -xar -o
To:
LIB = ar cr
cd /usr/local/agg
make
Install MapServer (v5.0)
patch -i fastlinesandpolygons.patch mapagg.cpp
vi configure
Remove or Comment Out:
{ { echo "$as_me:$LINENO: error:
!!! The current version of PHP MapScript requires PHP4 configured as !!!
!!! a CGI and cannot be used with PHP4 configured as an Apache module,!!!
!!! so you cannot use the --with-apxs option. !!!
!!! See: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI !!!" >&5
echo "$as_me: error:
!!! See: http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI !!!" >&2;}
{ (exit 1); exit 1; }; }
./configure --enable-ignore-missing-data --with-geos --with-proj --with-gdal --with-ogr \
--with-curl-config=/usr/local/bin/curl-config --with-xml2-config=/usr/local/bin/xml2-config \
--with-threads --without-tiff --without-pdf --with-freetype --with-oraclespatial=yes \
--with-wfs --with-wcs --with-wmsclient --with-wfsclient --with-php=/usr/local/php \
--with-png=/usr/local/lib --with-jpeg=/usr/local/lib --with-apxs=/usr/local/apache/bin/apxs \
--with-agg=/usr/local/agg
make
cd mapscript/perl ; perl Makefile.PL && make
install -o -u root -g root -m 755 -f /export/home/www/cgi-bin mapserv
install -o -u root -g root -m 655 -f /usr/local/php/lib/php mapscript/php3/php_mapscript.so
for i in legend scalebar tile4ms sortshp shptree shptreevis shp2pdf shp2img msencrypt shp2mysql.pl
do
install -o -u root -g root -m 755 -f /usr/local/bin $i
done
cd mapscript/perl ; make install
vi /usr/local/php/lib/php.ini
; Directory in which the loadable extensions (modules) reside.
extension_dir = "/usr/local/php/lib/php/"
; Dynamic Extensions ;
extension=php_mapscript.so
<IfModule alias_module>
Alias /ms_tmp/ "/export/home/www/ipcs/.cache/ms_tmp/"
<Location "/cgi-bin/">
SetEnv ORACLE_HOME /u01/app/oracle/product/10.2
SetEnv ORACLE_BASE /u01/app/oracle
SetEnv TNS_ADMIN /u01/app/oracle/product/10.2/network/admin
SetEnv ORACLE_SID nps
SetEnv LD_LIBRARY_PATH
/u01/app/oracle/product/10.2/lib:
/lib:/usr/lib:/usr/openwin/lib:/usr/td/lib:
/usr/ucblib:/usr/local/lib
</Location>
apachectl stop
apachectl start
