[mapserver-users] Label attribute bindings
deangadoury at subpixelmedia.com
Thu Jun 5 08:44:51 EDT 2008
This is only a partial answer, but if you have a label angle as an attribute in your data you should be able to use LABELANGLEITEM.
LABELANGLEITEM [attribute]
Item name in attribute table to use for class annotation angles. Values should be in degrees.
Dean Gadoury
Subpixel Media
subpixelmedia.com
> -------- Original Message --------
> Subject: [mapserver-users] Label attribute bindings
> From: Tim Urwin <t.urwin at ed.ac.uk>
> Date: Thu, June 05, 2008 4:25 am
> To: mapserver-users at lists.osgeo.org
> Hi all,
> This is a questuion about label attribute bindings.
> We are about to migrate some of our Ordnance Survey MasterMap data from
> a propriety system to using mapserver serving the data from a PostGIS
> database for screen maps. We are currently using Mapserver 5.02 and are
> very happy with the results we have achieved so far, however, due to
> only being able to set a single value for the position of a label has
> caused much of the text to be badly misaligned with the underlying features.
> OS has determined the best position for the label and provide this as
> attribute data for each text label point and we would like to be able to
> utilise it. Is there anyway to make the position label attribute accept
> a binding as some of the other values do, e.g. angle which we also use.
> The problem we have is that no single value works with the data to
> provide a good map result, therefore we would like to be able to use
> each feature's value as opposed to a global value.
> Any help or insights in how to achieve this will be gratefully received.
> At the moment our applications access Mapserver via CGI mode directly
> without the use of mapscript although we could investigate that option.
> The following is an example of one of the entries in the mapfile for a
> label layer.
> LAYER
> NAME "Heritage labels"
> METADATA
> "wms_title" "Heritage labels"
> "wms_srs" "EPSG:27700"
> "wms_extent" "0.0 0.0 700000.0 1300000.0"
> END
> STATUS OFF
> CONNECTIONTYPE postgis
> CONNECTION "user=XXXX password=XXXX dbname=XXXX host=XXXX port=XXXX"
> DATA '"anchorpoint" from "cartographictext" using unique "fid" using
> SRID=27700'
> PROCESSING "CLOSE_CONNECTION=DEFER"
> TYPE Annotation
> LABELITEM 'textstring'
> FILTER ("layer" = '59')
> CLASS
> NAME 'Antiquity Text (82)'
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> TYPE TRUETYPE
> FONT arial-italic
> SIZE 8
> ANGLE [angle]
> ANTIALIAS TRUE
> POSITION CC
> PARTIALS TRUE
> ENCODING 'UTF-8'
> END
> END
> MINSCALEDENOM 100.0
> MAXSCALEDENOM 5500.0
> PROJECTION
> "init=epsg:27700"
> END
> END
> many thanks
> Tim
> Tim Urwin
> EDINA
> The University of Edinburgh
> Causewayside House
> 160 Causewayside
> Edinburgh EH9 1PR
> tel: +44 (0) 131 650 3310
> fax: +44 (0) 131 650 3308
> email: t.urwin at ed.ac.uk
> The University of Edinburgh is a charitable body, registered in
> Scotland, with registration number SC005336.
