[mapserver-users] Map seems like it is shifted to the north by
a few meters
Ben Kuek
ben.kuek at abridge.com.au
Fri Jun 6 02:59:49 EDT 2008
Hi Robert,
Thank you for your response. I tried using the settings you recommended
on both the top level and the
layer object but the map remained the same.
I can now confirm the problem lies in the map source. Even using a well
known map viewer to compare it to
a reliable source like G00GLE maps, I can see the similar problem.
Cheers,
Ben
Robert Sanson wrote:
> Hi Ben
> This looks like WGS84. You should haev the following in your Map file,
> top level and/or layer level:
> PROJECTION
> "init=epsg:4326"
> END
> regards,
> Robert Sanson
> >>> Ben Kuek <ben.kuek at abridge.com.au> 28/05/2008 3:44:09 p.m. >>>
> Hi,
> My understanding of map projections is a bit rusty so I hope anyone can
> point out where I am wrong.
> I have a vector map source in shapefiles where it's .prj file has only
> the following definition
> GEOGCS["Geographic Coordinate System",DATUM["WGS84",SPHEROID["GRS
> 1980",6378137,298.2572220960423]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]
> When the map loaded, I can confirm that the map is wrong by it's
> shifting to the north by a few hundred meters.
> I can use :
> OFFSET 0 70
> in the STYLE object but it doesn't seem like the right thing to do.
> I am not very sure if the issue lies with projection or the map source
> and if there's a specific projection setting I must use.
> Regards,
> Ben
> mapserver-users at lists.osgeo.org
> The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com <http://www.surfcontrol.com/>
> No virus found in this incoming message.
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 269.24.1/1469 - Release Date: 27/05/2008 1:25 PM
