[mapserver-users] Label attribute bindings
Tim Urwin
t.urwin at ed.ac.uk
Fri Jun 6 03:21:04 EDT 2008
Steve,
Thanks for that. Will certainly try it.
Tim
Stephen Woodbridge wrote:
> Tim,
> Well in that case you should be able to set CLASSITEM to your position
> attribute. And then set up a CLASS for each position. This is UGLY in
> the mapfile, but you should be able to do it now without code changes.
> -Steve
> Tim Urwin wrote:
>> Hi Steve,
>> Unfortunatly not, it is a single digit 1-9 in an attribute field
>> which we mapped to the two letter characters used by mapserver for
>> text position, eg ll cc etc. We would just like to be able to look
>> this up for each feature rather than apply a blanket approach for the
>> layer. We would prefer not to edit the data as it changes get updated
>> on a regular basis (we get updates every 6 to 8 weeks from ordnance
>> suervey) and the database table has just under 22 and a half million
>> entries.
>> Thanks
>> Tim
>>> Tim,
>>> When you say "OS has determined the best position for the label",
>>> what form is this attribute in? Is the x-y position attribute
>>> columns? or some offset x-y attribute? or what?
>>> If it is an x-y position that you would rather use that the default
>>> the_geom geometry position of the feature then it would probably be
>>> possible to create a view that makes that x-y appear as
>>> setsrid(makepoint(x_col,y_col),27700) as the_geom in the view and
>>> then add a record to the geometry_columns table for this view. for
>>> performance you might want to add this column to the orginal table
>>> and index it.
>>> Then you should be able to renter the annotation using the view or
>>> the alternate column in the table.
>>> -Steve W
>>> Tim Urwin wrote:
>>>> Hi all,
>>>> This is a questuion about label attribute bindings.
>>>> We are about to migrate some of our Ordnance Survey MasterMap data
>>>> from a propriety system to using mapserver serving the data from a
>>>> PostGIS database for screen maps. We are currently using Mapserver
>>>> 5.02 and are very happy with the results we have achieved so far,
>>>> however, due to only being able to set a single value for the
>>>> position of a label has caused much of the text to be badly
>>>> misaligned with the underlying features.
>>>> OS has determined the best position for the label and provide this
>>>> as attribute data for each text label point and we would like to be
>>>> able to utilise it. Is there anyway to make the position label
>>>> attribute accept a binding as some of the other values do, e.g.
>>>> angle which we also use. The problem we have is that no single
>>>> value works with the data to provide a good map result, therefore
>>>> we would like to be able to use each feature's value as opposed to
>>>> a global value.
>>>> Any help or insights in how to achieve this will be gratefully
>>>> received. At the moment our applications access Mapserver via CGI
>>>> mode directly without the use of mapscript although we could
>>>> investigate that option.
>>>> The following is an example of one of the entries in the mapfile
>>>> for a label layer.
>>>> LAYER
>>>> NAME "Heritage labels"
>>>> METADATA
>>>> "wms_title" "Heritage labels"
>>>> "wms_srs" "EPSG:27700"
>>>> "wms_extent" "0.0 0.0 700000.0 1300000.0"
>>>> END
>>>> STATUS OFF
>>>> CONNECTIONTYPE postgis
>>>> CONNECTION "user=XXXX password=XXXX dbname=XXXX host=XXXX port=XXXX"
>>>> DATA '"anchorpoint" from "cartographictext" using unique "fid"
>>>> using SRID=27700'
>>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>>> TYPE Annotation
>>>> LABELITEM 'textstring'
>>>> FILTER ("layer" = '59')
>>>> CLASS
>>>> NAME 'Antiquity Text (82)'
>>>> LABEL
>>>> COLOR 0 0 0
>>>> OUTLINECOLOR 255 255 255
>>>> TYPE TRUETYPE
>>>> FONT arial-italic
>>>> SIZE 8
>>>> ANGLE [angle]
>>>> ANTIALIAS TRUE
>>>> POSITION CC
>>>> PARTIALS TRUE
>>>> ENCODING 'UTF-8'
>>>> END
>>>> END
>>>> MINSCALEDENOM 100.0
>>>> MAXSCALEDENOM 5500.0
>>>> PROJECTION
>>>> "init=epsg:27700"
>>>> END
>>>> END
>>>> many thanks
>>>> Tim
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
