[mapserver-users] SLD implementation - fill-opacity
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Jun 6 10:42:24 EDT 2008
Guillaume Sueur wrote:
> Hi, Assefa,
> Do you mean I have to use AGG to get benefit from opacity settings in SLD ?
> Thanks
Yesy : the SLD will always parse and set the style's opacity parameter.
But since only the AGG output uses it when rendering the map, you
would need to set your output to AGG to see the effects.
> Yewondwossen Assefa a écrit :
>> Hi there,
>> Actually the style->opacity parameter was there for a while although
>> not used until recently. The SLD (mapserver svn) already reads the
>> stoke/fill-opacity and set the parameter. Note that this only the AGG
>> output supports opacity at style level.
>> Please report an issue through bug 2638 if opacity with AGG output is
>> not working as expected.
>> Best Regards,
>> bartvde at osgis.nl wrote:
>>> I am quite sure this is because back then Mapserver only supported
>>> layer-level transparency, and not style-level transparency.
>>> With the new addition of style-level transparency in trunk, it should
>>> become possible to implement this now AFAICT. Maybe open up an
>>> enhancement
>>> ticket for this?
>>> Best regards,
>>> Bart
>>> On Fri, 06 Jun 2008 14:52:28 +0200, Guillaume Sueur
>>> <guillaume.sueur at neogeo-online.net> wrote:
>>>> Hi folks,
>>>> Does Mapserver SLD implementation supports the fill-opacity css
>>>> parameter ? As far as I can see, it doesn't. Bug ?
>>>> Thanks
>>>> Guillaume
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
