[mapserver-users] SLD implementation - fill-opacity
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Fri Jun 6 13:39:10 PDT 2008
I still don't have a the desired rendering, even with AGG... I'm using
5.0.1 dev version, should I upgrade to the last SVN version ?
thanks
Yewondwossen Assefa a écrit :
> Guillaume Sueur wrote:
>> Hi, Assefa,
>> Do you mean I have to use AGG to get benefit from opacity settings in
>> SLD ?
>> Thanks
> Yesy : the SLD will always parse and set the style's opacity parameter.
> But since only the AGG output uses it when rendering the map, you would
> need to set your output to AGG to see the effects.
>>> Hi there,
>>> Actually the style->opacity parameter was there for a while although
>>> not used until recently. The SLD (mapserver svn) already reads the
>>> stoke/fill-opacity and set the parameter. Note that this only the AGG
>>> output supports opacity at style level.
>>> Please report an issue through bug 2638 if opacity with AGG output
>>> is not working as expected.
>>> Best Regards,
>>> bartvde at osgis.nl wrote:
>>>> I am quite sure this is because back then Mapserver only supported
>>>> layer-level transparency, and not style-level transparency.
>>>> With the new addition of style-level transparency in trunk, it should
>>>> become possible to implement this now AFAICT. Maybe open up an
>>>> enhancement
>>>> ticket for this?
>>>> Best regards,
>>>> Bart
>>>> On Fri, 06 Jun 2008 14:52:28 +0200, Guillaume Sueur
>>>> <guillaume.sueur at neogeo-online.net> wrote:
>>>>> Hi folks,
>>>>> Does Mapserver SLD implementation supports the fill-opacity css
>>>>> parameter ? As far as I can see, it doesn't. Bug ?
>>>>> Thanks
>>>>> Guillaume
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 74 91 95 20
Site web : http://www.neogeo-online.net
More information about the MapServer-users
