[MAPSERVER-USERS] help! agg palette quantize algorithmimperfection
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Jun 6 17:04:47 EDT 2008
I've generated palettes by rendering a large 24-bit sample image and then reducing colors using
tools like Photoshop, GIMP or ImageMagick. Then I just run gdalinfo output on the reduced color
image through a perl script to extract the palette.
#!/usr/bin/perl
$doit = 0;
while(<>) {
if($_ =~ /Color Table/) {
$doit = 1;
next;
if($doit) {
($r,$g,$b,$a) = split /,/, substr($_,7);
print "$r,$g,$b\n";
Works just fine...
Steve
>>> On 6/6/2008 at 3:24 PM, in message <17700473.post at talk.nabble.com>, BrainDrain
<paulborodaev at gmail.com> wrote:
> $? You're kidding)) Anyway, thanks for advise. Will try.
> And what about agg rgba mode (bug, invalid color interpretation (inverting?)
> or something like that)? When
> this problem will be fixed? I need it, because I want to use map
> transparency (only rgba mode) to combine with google map layer in openlayers
> rich client app.
> Stephen Woodbridge wrote:
>> Hey, that's what they pay you the BIG BUCKS for! :)
>> Write a perl/bash/{your favorite} script to grab all the COLOR lines
>> from you mapfile and reformat the r g b to r,g,b in you palette file.
>> I have a few hundred symbols in my symbol library, but I only use about
>> 10 of them regularly so I made sure the primary colors were also in the
>> palette file. I make the script add them so I don't have to think about
>> it.
>> It sounds like a big deal, but it not that bad.
>> YMMV,
>> -Steve W
>> BrainDrain wrote:
>>> Thanks, i already read about preparing palette index file & I see 2
>>> obstacles:
>>> 1) I need to monitor my map file (big size) to keep relevant my palette
>>> file. It is inflexible to extract rgb colors used in pixmap symbols
>>> (hundreds, updatable). Can I use html palette for ex. (or any other
>>> 'universal' palette) - to make this process not so time-consuming?
>>> 2) If I have strict palette, can I be sure that agg renderer will always
>>> use
>>> the nearest(?) color from my palette?
>>> pagameba wrote:
>>>> Use:
>>>> OUTPUTFORMAT
>>>> OUTPUTFORMAT
>>>> NAME "AGG_Q"
>>>> DRIVER "AGG/PNG"
>>>> MIMETYPE "image/png; mode=8bit"
>>>> IMAGEMODE RGB
>>>> EXTENSION "png"
>>>> FORMATOPTION "PALETTE_FORCE=TRUE"
>>>> FORMATOPTION "PALETTE=/path/to/palette.txt"
>>>> END
>>>> where palette.txt is a text file with RGB tuples in the form:
>>>> RRR,GGG,BBB
>>>> For example:
>>>> 0,0,0
>>>> 255,255,255
>>>> 127,127,127
>>>> MapServer will use AGG 24 bit rendering but reduce the output file to
>>>> 8 bit and reserve the colours in your palette.txt file. This will
>>>> give you consistent colours for the ones you care about.
>>>> Specifically, you should reserve all the colours that you actually
>>>> reference in your map file plus any colours of pixmap symbols. Don't
>>>> put in more colours than you actually need to because MapServer needs
>>>> to use whatever space is left (255 less your colours) for antialiasing.
>>>> Cheers
>>>> Paul
>>>> On 6-Jun-08, at 7:53 AM, BrainDrain wrote:
>>>>> I use this output format in my map file:
>>>>> OUTPUTFORMAT
>>>>> NAME "AGG_Q"
>>>>> DRIVER "AGG/PNG"
>>>>> IMAGEMODE RGB
>>>>> EXTENSION "png"
>>>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>>>> FORMATOPTION "QUANTIZE_COLORS=256"
>>>>> END
>>>>> but every time map draw called (or map image requested fom cgi
>>>>> mapserv.exe)
>>>>> polygons has a little difference in fill color (I think this is
>>>>> because
>>>>> color palette recalculated slightly different each time). This is
>>>>> unacceptable for me. How can i correct this? (maybe some
>>>>> FORMATOPTION?)
>>>>> View this message in context:
> http://www.nabble.com/help%21-agg-palette-quantize-algorithm-imperfection-tp1766773
> 3p17667733.html
>>>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> Paul Spencer
>>>> Chief Technology Officer
>>>> DM Solutions Group Inc
>>>> http://www.dmsolutions.ca/
