[mapserver-users] mapserver wms: srs problem
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 9 21:19:11 EDT 2008
Maybe you could attach your entire .map file for the mailing list to
see.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
On 9-Jun-08, at 4:44 PM, Matthew Pettis wrote:
> Hi Barend, All,
> I tried your suggested changes:
> PROJECTION
> "init=epsg:4326"
> END
> # Web settings
> WEB
> IMAGEPATH "C:/ms4w/Apache/htdocs/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wms_title" "WMS Demo Server"
> "wms_onlineresource"
> "http://localhost/cgi-bin/mapserv.exe?center=45,-95&zoom=6"
> "wms_srs" "EPSG:4326 EPSG:26915"
> END
> END
> # State
> # Background shows through missing precincts to show where no
> votes will be coming from
> LAYER
> NAME "state"
> METADATA
> "wms_title" "state"
> "wms_format" "image/png"
> END
> Now, the map is blank (no error messages either). It looks like i can
> drag and zoom per the controls, but there is no image of the state of
> MN to move around. Any idea what could still be the matter?
> Thanks,
> Matt
> On Sun, Jun 8, 2008 at 1:08 PM, Barend Kobben <kobben at itc.nl> wrote:
>> It looks like your datastore's SRS is 4326 (latlon on the WGS84).
>> In other
>> words, the data in your shapefile, database or raster image are (or
>> are
>> advertised to be) in 4326. Its because your data is indeed in that
>> srs
>> and/or advertised as such in the Mapfile LAYER as
>> PROJECTION
>> "init=epsg:4326"
>> END
>> But you tell the WMS interface that the layer is in 26915, by
>> setting layer
>> metadata srs => EPSG:26915
>> If you want MS to reproject your data from 4326 to 26915 upon
>> request, make
>> sure you set the layerdata projection:
>> PROJECTION
>> "init=epsg:4326"
>> END
>> Then make sure you tell the WMS interface to advertise it can be
>> reprojected
>> to 26915 by setting it in web metadata srs:
>> "wms_srs" "EPSG:4326 EPSG:26915 EPSG:[others you want to offer]"
>> AFAIK there no wms_srs metadata in the LAYER object...
>> Barend Köbben
>> International Institute for Geo-Information
>> Sciences and Earth Observation (ITC)
>> PO Box 6
>> 7500AA Enschede, The Netherlands
>> +31 (0)53 4874253
>> On 08-06-08 02:21, "Matthew Pettis" <matthew.pettis at gmail.com> wrote:
>>> Hi,
>>> I am not a GIS guy, and am a bit confused by the projection
>>> attributes
>>> i have to specify in mapserver. In particular, I have a simple
>>> example. I have a map that has the following metadata:
>>> Horizontal Coordinate Scheme UTM
>>> Ellipsoid GRS80
>>> Horizontal Datum NAD83
>>> Horizontal Units Meters
>>> UTM Zone Number 15
>>> I believe this translates to an epsg=26915
>>> Now, according to mapserver, I have to specify a projection
>>> object, a
>>> web metadata srs, and a layer metadata srs.
>>> To compress the mapfile, i'll just note what i have specified for
>>> each
>>> of these settings.
>>> First, I would think that this would work:
>>> projection => init=epsg:26915
>>> web metadata srs => EPSG:26915
>>> layer metadata srs => EPSG:26915
>>> this give me the error:
>>> msWMSLoadGetMapParams(): WMS Server Error. Invalid SRS given. SRS
>>> must be valid for all requested layers.
>>> I only have the one layer (it's of the state of MN from www.gis.leg.mn
>>> However, the following renders, but I don't think it is the
>>> projection
>>> i want (as the top of MN is too wide):
>>> layer metadata srs => EPSG:4326
>>> Now, I am using mapserver as a WMS. Before I was using it NOT as a
>>> WMS, but just making it render the shapefile without any projection
>>> information, it worked, and it was the projection I had come to
>>> expect
>>> when seeing the state of MN rendered.
>>> Why does my first configuration give me an error?
>>> How can I make it render in the way I expect without giving
>>> mapserver
>>> explicit projection instructions?
>>> please forgive the ignorance of map projection knowledge.
>>> thanks,
>>> matt
>> International Institute for Geo-Information Science and Earth
>> Observation (ITC)
>> Chamber of Commerce: 410 27 560
>> E-mail disclaimer
>> The information in this e-mail, including any attachments, is
>> intended for the addressee only. If you are not the intended
>> recipient, you are hereby notified that any disclosure, copying,
>> distribution or action in relation to the content of this
>> information is strictly prohibited. If you have received this e-
>> mail by mistake, please delete the message and any attachment and
>> inform the sender by return e-mail. ITC accepts no liability for
>> any error or omission in the message content or for damage of any
>> kind that may arise as a result of e-mail transmission.
> It is from the wellspring of our despair and the places that we are
> broken that we come to repair the world.
> -- Murray Waas
> mapserver-users at lists.osgeo.org
