[mapserver-users] PointM shapefile not displaying outside its extent
Pano Voudouris
pvoudouris at gaiocorp.com
Fri Jun 13 02:51:38 EDT 2008
Hi All,
I have a pointM shapefile that justs refuse to display as soon as I pan the
map (same scale) so part of the shapes go beyond the map extent. It will
only display if all points are within the view window. I dropped and
recreated the spatial index, used the shptree to create the *qix file but
all to no avail. I have stripped down the layer to the bare basics. The
entry in the mapfile is:
LAYER
NAME "DEFS"
STATUS DEFAULT
TYPE POINT
DATA defects2
METADATA
WMS_TITLE "defects"
END #end metadata
CLASS
STYLE
SYMBOL "point"
SIZE 12
COLOR 0 170 0
#MAXSIZE 100
#MINSIZE 50
END
END
END
I only managed to display it after I converted it to simple points (not
PointM). Is this some sort of limitation in Mapserver? It can display
PolylineM w/out any problems.
Thanks in anticipation,
Pano
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080613/3c1242bf/attachment.html
