[mapserver-users] PointM shapefile not displaying outside its
extent
Frank Warmerdam
warmerdam at pobox.com
Wed Jun 18 11:07:27 EDT 2008
Pano,
I would suggest you file a ticket with all the details to reproduce
the problem in a minimal way.
It is not at all obvious to me why this would happen.
Best regards,
Pano Voudouris wrote:
> Anyone? Please?
> Hi All,
> I have a pointM shapefile that justs refuse to display as soon as I pan
> the map (same scale) so part of the shapes go beyond the map extent. It
> will only display if all points are within the view window. I dropped
> and recreated the spatial index, used the shptree to create the *qix
> file but all to no avail. I have stripped down the layer to the bare
> basics. The entry in the mapfile is:
> LAYER
> NAME "DEFS"
> STATUS DEFAULT
> TYPE POINT
> DATA defects2
> METADATA
> WMS_TITLE "defects"
> END #end metadata
> CLASS
> STYLE
> SYMBOL "point"
> SIZE 12
> COLOR 0 170 0
> #MAXSIZE 100
> #MINSIZE 50
> END
> END
> END
> I only managed to display it after I converted it to simple points (not
> PointM). Is this some sort of limitation in Mapserver? It can display
> PolylineM w/out any problems…
> Thanks in anticipation,
> Pano
> mapserver-users at lists.osgeo.org
and watch the world go round - Rush | President OSGeo, http://osgeo.org
