[mapserver-users] PointM shapefile not displaying outside its extent
Wed Jun 18 08:07:27 PDT 2008
Pano,
I would suggest you file a ticket with all the details to reproduce
the problem in a minimal way.
It is not at all obvious to me why this would happen.
Best regards,
Pano Voudouris wrote:
> Anyone? Please?
> Hi All,
> I have a pointM shapefile that justs refuse to display as soon as I pan
> the map (same scale) so part of the shapes go beyond the map extent. It
> will only display if all points are within the view window. I dropped
> and recreated the spatial index, used the shptree to create the *qix
> file but all to no avail. I have stripped down the layer to the bare
> basics. The entry in the mapfile is:
> LAYER
>         NAME "DEFS"
>         STATUS DEFAULT
>         TYPE POINT
>             DATA defects2
>         METADATA
>             WMS_TITLE "defects"
>         END #end metadata
>         CLASS
>             STYLE
>               SYMBOL "point"
>               SIZE 12
>               COLOR 0 170 0
>              #MAXSIZE 100
>              #MINSIZE 50
>             END
>        END
>   END
> I only managed to display it after I converted it to simple points (not
> PointM). Is this some sort of limitation in Mapserver? It can display
> PolylineM w/out any problems…
> Thanks in anticipation,
> Pano
> mapserver-users at lists.osgeo.org
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the MapServer-users mailing list
