[mapserver-users] MapServer 5.2 Beta 2 Available
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Jun 19 00:00:22 EDT 2008
Hi folks: MapServer 5.2 Beta 2 has just been released. The source package is available for download at:
http://mapserver.gis.umn.edu/download/beta
The list of changes/fixes since 5.2-beta1 can be found at the end this message. This is a significant release so
we need your help in testing. 5.2 should compatible with any 5.0 applications/mapfiles so it should be
relatively easy for folks to test. Please let us know how it goes!
The plan is now to have 3 beta releases, 1 release candidate with a final release the first week in July.
More details can be found in the 5.2 release plan at:
http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_2/release_plan/
Steve
Version 5.2.0-beta2 (2008-06-18):
- Fixed possible buffer overrun with Oracle Spatial driver (#2572)
- mapogcsos.c: support srsName in GetObservation (#2414)
- Filter Encoding: Modify DWithin definition (#2564)
- Added webObj legendformat and browseformat mapping in PHP MapScript (#2309)
- Removed static buffer size limit in msIO_*printf() functions (#2214)
- Fixed libiconv detection in configure for OSX 10.5 64 bit (#2396)
- mapstring.c: possible buffer overflow in msGetPath (#2649)
- maputil.c: Correct expression evaluation with text containing
apostrophes (#2641)
- mapwfs.c: Possibly generate an error message when applying filter
encoding (#2444)
- Added MS_LABEL_BINDING constants for SWIG MapScript (#2643)
- mapogcsos.c: fix POST support (#2379)
- maplibxml2.c: helper functions XML POST fix (#2379)
- mapwfs.c: fix segfault when srsName is not passed on BBOX Filter (#2644)
- mapwfs.c: do not return error for empty query results (#2444)
- Remove C++-style comments and most other warnings thrown by -pedantic (#2598)
- mapwfs.c/mapwfs11.c: set GML MIME type correctly
- mapogcsos.c: advertise supported SRS list via
MAP.WEB.METADATA.sos_srs (#2414)
- mapwfs.c: set layer extent to map extent for default
GetFeature requests with no spatial predicates (#1287)
