[mapserver-users] VRT into a symbol definition
Tamas Szekeres
szekerest at gmail.com
Fri Jun 20 08:01:46 EDT 2008
I believe you can only specify real raster files to define pixmap
symbols the VRT files can only be processed by the GDAL driver like
drawing raster layers.
Do you have an exact algorithm to assign mapserver symbol definitions
to the mapinfo symbol specification. I wonder if the STYLEITEM "AUTO"
option could be extended for this case. For more information see:
http://mapserver.gis.umn.edu/docs/howto/ogr_howto/#styleitem-auto-rendering-layers-using-style-information-from-the-ogr-file
Best regards,
Tamas
2008/6/20 "SAEZ Laurent - CETE Méditerr./DI/ETER"
<Laurent.Saez at developpement-durable.gouv.fr>:
> Hi list,
> I've tried to use VRT files into a symbol definition, but it doesn't work.
> It will be fine.
> I've to reproduce MapInfo(R) hatches. MapInfo(R) uses raster to make hatches.
> I've recovered all the raster. But I need to reproduce all front colors and
> all background colors.
> So, I've tried to make VRT files instead of generating all real raster
> files. It seems to be not possible...
> So I've had to make thousands real raster files. I've written few lines code
> to make all vrt files and I've used gdal_translate to make all real raster
> files.
> Is there a solution to use VRT file into a symbol definition ?
> Thanks for help
> mapserver-users at lists.osgeo.org
