[mapserver-users] MapServer 5.2 Beta 2 Available
Håvard Tveite
havard.tveite at umb.no
Mon Jun 23 09:18:52 EDT 2008
I had the same problem, and it turned out to be a bug
(http://trac.osgeo.org/mapserver/ticket/2655), which
is now resolved, so it should be OK in the upcoming
beta 3.
Håvard
Tony Frame wrote:
> On Wed, 2008-06-18 at 23:00 -0500, Steve Lime wrote:
>> Hi folks: MapServer 5.2 Beta 2 has just been released. The source package is available for download at:
>> http://mapserver.gis.umn.edu/download/beta
>> The list of changes/fixes since 5.2-beta1 can be found at the end this message. This is a significant release so
>> we need your help in testing. 5.2 should compatible with any 5.0 applications/mapfiles so it should be
>> relatively easy for folks to test. Please let us know how it goes!
>> The plan is now to have 3 beta releases, 1 release candidate with a final release the first week in July.
>> More details can be found in the 5.2 release plan at:
>> http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_2/release_plan/
>> Steve
> I've tried both 5.2.0-beta1 and 5.2.0-beta2 and have the same problem -
> everything works fine except no map image is generated. Ref map and
> scale bar images are generated fine - just the main map image never
> appears. Same map file works fine with 5.0.3. Details of config / system
> are as follow :
> OS : Fedora 9
> Arch : same result on I386 and X86_64
> Config options : --with-ogr --with-gdal --with-agg --with-freetype
> --with-proj
> Method of use : cgi
> Image format : png
> Nothing unusual reported in mapserver log file, httpd logs or selinux
> logs.
> shp2img generates the map image from the map file without any problems.
> Its also not a path reference problem - the map image never appears in
> the tmp directory but both the ref map and scale bar images do.
> Regards
> Tony
