[MAPSERVER-USERS] Mapserver does partial search of dbf file
Fawcett, David
David.Fawcett at state.mn.us
Mon Jun 23 13:54:41 PDT 2008
Do the missing features fall outside of the extent defined in the map
file? If they are not within the exent, they won't be returned by an
item query (at least that is the way that it worked some time ago...)
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of JayDub
Sent: Monday, June 23, 2008 3:31 PM
To: mapserver-users at lists.osgeo.org
Subject: [MAPSERVER-USERS] Mapserver does partial search of dbf file
Hi all, I'm having a severe problem with MapServer. It seems to only be
searching PARTS of a dbf file. Have a look at my layer.
LAYER
NAME "AllFaculties"
DATA '/home/jolly/web/shps/campus/mit/buildings.shp'
TRANSFORM true
CLASSITEM 'Name'
TYPE polygon
GROUP "AllFaculties"
METADATA
"queryable" "true"
"searchfield" "Name"
"fields" "Name:name,Category:cat"
END # METADATA
CLASS
TEMPLATE "template.html"
END # CLASS
END # LAYER
Simple and to the point... some how there are records in the dbf file
that I can't reach via search. I'm using kamap's search script that
basically uses mapscript's queryByAttributes(.....) to get results.
Id Category Name
0 Residence/Hall Karma Hall
0 Residence/Hall Terry Hall
Above is an extract of my dbf file... Mapserver finds the first record
but does not find the 2nd record. And that's generally how it is with my
dbf file. It'll find a record here and then not find a couple that
follow after, then it's able to find records that follow after.
Hope some one can help... coz this project was due 3 fridays ago and my
boss is a lil... perturbed (to be MOST diplomatic, and naive)
View this message in context:
http://www.nabble.com/Mapserver-does-partial-search-of-dbf-file-tp180777
80p18077780.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
