[mapserver-users] Expression encoding must be in the same encoding
than the data
"SAEZ Laurent - CETE Méditerr./DI/ETER"
Laurent.Saez at developpement-durable.gouv.fr
Wed Jun 25 07:51:01 EDT 2008
Thank you,
But my problem is not concerning labels but the raster with polylines.
I'm aware that there is a solution for labels.
I'm interestring with the solution for the geometry returned by my
classification.
Best regards
Laurent
Le 25/06/2008 13:09, > Tamas Szekeres (par Internet) a écrit :
> Hi,
> It seem you should have libiconv compiled in, and specify the encoding
> in the label definitions, like:
> LABEL
> ENCODING ISO-8859-1
> END
> Best regards,
> Tamas
> 2008/6/25 "SAEZ Laurent - CETE Méditerr./DI/ETER"
> <Laurent.Saez at developpement-durable.gouv.fr>:
>> Hi list,
>> Encoding in expression is not very simple...
>> I have :
>> mapserver 4.99,
>> a mapfile utf-8 encoded,
>> a mapinfo file create on windows (encoding cp1252),
>> one class using a field which contain this value : "Départementale".
>> If I write in the mapfile the following expression :
>> CLASS
>> NAME "Départementale"
>> EXPRESSION "Départementale"
>> This class is not in the raster returned by the WMS/GetMap request.
>> To obtain this class I have to encode the string expression in the same
>> encoding than the data (mapinfo tab) :
>> CLASS
>> EXPRESSION "D�partementale"
>> So it's strange to encode a string in cp1252 (or iso-8859-1) in a file
>> encoding in utf-8.
>> Is there a way to tell mapserver that my layer is cp1252 encoded ?
>> Thanks for help
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
