[mapserver-users] 2 STYLE with 2 different SIZEITEM... bug?
Federica De Martin
federica.demartin at gmail.com
Fri Jun 27 10:58:47 EDT 2008
Hi Paul,
my values are stored in integer fields, but I calculate the value I use in a
Postgres query with a user defined function that returns a string; Now I
have also tried making a cast to integer in the Query but I keep on getting
this Error:
*Warning*: [MapServer Error]: getInteger(): Parsing error near ([):(line
539) in *..../chameleon-2.4/htdocs/common/wrapper/map_session.php* on line *215
*if I use the expression SIZE [sizeobj1] and
([sizeobj1]):(line 539) in *
..../chameleon-2.4/htdocs/common/wrapper/map_session.php* on line *215 *
if I use the expression SIZE "[sizeobj1]".... I use Chameleon, is there any
problem?
(my configuration is Mapserver 4.10 with Chameleon 2.4 on Linux Ubuntu 6.10)
Bye Federica
2008/6/27 Paul Spencer <pspencer at dmsolutions.ca>:
> Are the values in your data stored as integer fields?
> The [field_name] syntax should substitute the attribute value for each
> feature as it is drawn, so it won't work with SIZEITEM, only with SIZE.
> No other ideas at this time.
> Cheers
> Paul
> On 27-Jun-08, at 9:29 AM, Federica De Martin wrote:
> Thank you for the answer!
>> I tried to user SIZE [field_name] and SIZE "[field_name]" but in both
>> cases I get [Mapserver Error]: getInteger(). Then I tried also SIZEITEM
>> [field_name] and SIZEITEM "[field_name]" that don't work and SIZEITEM
>> field_name that makes me get the same result as SIZEITEM "field_name"....
>> Any other idea or workaround?
>> Federica
>> Try the following:
>> CLASS
>> NAME "calss1"
>> STYLE # first style
>> SYMBOL "cartoline_square"
>> SIZE [sizeobj2]
>> COLOR 0 0 0 #black
>> END
>> STYLE # second style
>> SIZE [sizeobj1]
>> COLOR 255 255 255 #white
>> END
>> END
>> Cheers
>> Paul
>> On 27-Jun-08, at 6:32 AM, Federica De Martin wrote:
>> Hi everybody,
>> I'm trying to use the SIZEITEM to render a line LAYER. My problem is that
>> when I use the SIZEITEM mapserver follows it only for the first style; this
>> is my class:
>> CLASS
>> NAME "calss1"
>> STYLE # first style
>> SIZEITEM "sizeobj2"
>> COLOR 0 0 0 #black
>> END
>> SIZEITEM "sizeobj1"
>> END
>> END
>> The values are: sizeobj2=sizeobj1+2; What I get is that the black lines
>> are of different sizes and the white lines (over the first) always keep the
>> same size (the smaller).
>> The symbol "cartoline_square" is a symbol of type cartoline, but I also
>> tried with other symbols and I get the same result.
>> Is there any bug or have I made something wrong in my class?
>> I wait for some help, Thanks.
>> Bye, Federca.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://www.dmsolutions.ca/
> Paul Spencer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080627/1ee07bb9/attachment-0001.html
