[mapserver-users] 2 STYLE with 2 different SIZEITEM... bug?
Paul Spencer
pspencer at dmsolutions.ca
Fri Jun 27 11:35:29 EDT 2008
Oh - the attribute binding stuff using [fieldname] is only available
in mapserver 5 I think.
Paul
On 27-Jun-08, at 10:58 AM, Federica De Martin wrote:
> Hi Paul,
> my values are stored in integer fields, but I calculate the value I
> use in a Postgres query with a user defined function that returns a
> string; Now I have also tried making a cast to integer in the Query
> but I keep on getting this Error:
> Warning: [MapServer Error]: getInteger(): Parsing error near ([):
> (line 539) in ..../chameleon-2.4/htdocs/common/wrapper/
> map_session.php on line 215
> if I use the expression SIZE [sizeobj1] and
> ([sizeobj1]):(line 539) in ..../chameleon-2.4/htdocs/common/wrapper/
> if I use the expression SIZE "[sizeobj1]".... I use Chameleon, is
> there any problem?
> (my configuration is Mapserver 4.10 with Chameleon 2.4 on Linux
> Ubuntu 6.10)
> Bye Federica
> 2008/6/27 Paul Spencer <pspencer at dmsolutions.ca>:
> Are the values in your data stored as integer fields?
> The [field_name] syntax should substitute the attribute value for
> each feature as it is drawn, so it won't work with SIZEITEM, only
> with SIZE.
> No other ideas at this time.
> Cheers
> Paul
> On 27-Jun-08, at 9:29 AM, Federica De Martin wrote:
> Thank you for the answer!
> I tried to user SIZE [field_name] and SIZE "[field_name]" but in
> both cases I get [Mapserver Error]: getInteger(). Then I tried also
> SIZEITEM [field_name] and SIZEITEM "[field_name]" that don't work
> and SIZEITEM field_name that makes me get the same result as
> SIZEITEM "field_name"....
> Any other idea or workaround?
> Federica
> Try the following:
> CLASS
> NAME "calss1"
> STYLE # first style
> SYMBOL "cartoline_square"
> SIZE [sizeobj2]
> COLOR 0 0 0 #black
> END
> STYLE # second style
> SIZE [sizeobj1]
> COLOR 255 255 255 #white
> END
> END
> Cheers
> Paul
> On 27-Jun-08, at 6:32 AM, Federica De Martin wrote:
> Hi everybody,
> I'm trying to use the SIZEITEM to render a line LAYER. My problem is
> that when I use the SIZEITEM mapserver follows it only for the first
> style; this is my class:
> CLASS
> NAME "calss1"
> STYLE # first style
> SIZEITEM "sizeobj2"
> COLOR 0 0 0 #black
> END
> SIZEITEM "sizeobj1"
> END
> END
> The values are: sizeobj2=sizeobj1+2; What I get is that the black
> lines are of different sizes and the white lines (over the first)
> always keep the same size (the smaller).
> The symbol "cartoline_square" is a symbol of type cartoline, but I
> also tried with other symbols and I get the same result.
> Is there any bug or have I made something wrong in my class?
> I wait for some help, Thanks.
> Bye, Federca.
> mapserver-users at lists.osgeo.org
> __________________________________________
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
> Paul Spencer
Paul Spencer
