[mapserver-users] WMS, SLD, FilterEncoding and PropertyIsLike
bartvde at osgis.nl
bartvde at osgis.nl
Mon Jun 30 05:30:40 EDT 2008
<4864E58F.1020007 at neogeo-online.net>
<4864E781.7010809 at dmsolutions.ca> <4868A508.6020008 at neogeo-online.net>
Message-ID: <3fa2d6410a8df0a7b10f97bce0857f39 at pop02.backbone.tiscomhosting.nl>
X-Sender: bartvde at osgis.nl
Received: from b50-11.minvenw.nl [145.50.39.11] with HTTP/1.1 (POST); Mon, 30
Jun 2008 11:30:40 +0200
User-Agent: RoundCube Webmail/0.1
Content-Type: text/plain; charset="UTF-8"
Content-Transfer-Encoding: 8bit
No Mapserver is right in this case it uses SLD 1.0 which is tied to Filter
1.0, see:
http://schemas.opengis.net/filter/1.0.0/filter.xsd
<xsd:attribute name="escape" type="xsd:string" use="required"/>
Btw, in Filter 1.1 the OGC changed this to:
http://schemas.opengis.net/filter/1.1.0/filter.xsd
<xsd:attribute name="escapeChar" type="xsd:string" use="required"/>
Best regards,
Bart
On Mon, 30 Jun 2008 11:19:04 +0200, Guillaume Sueur
<guillaume.sueur at neogeo-online.net> wrote:
> Folks, I've found the trick !
> Where OGC SLD specification says :
> <PropertyIsLike wildCard="*" singleChar="#" escapeChar="!">
> MapServer wants :
> <PropertyIsLike wildCard="*" singleChar="#" escape="!">
> Using the first expression with MapServer causes the filter set with it
> to apply to every records.
> Should I submit a ticket for this ?
> Guillaume
> Yewondwossen Assefa a écrit :
>> Guillaume,
>> Attaches is an sld I use for testing and mapsever returns the expected
>> results. If you do not mind sharing your sld, you can send it to me and
>> I can have a look.
>> Best Regards,
>> Guillaume Sueur wrote:
>>> actually it helped me going further in my analysis :
>>> when I use PropertyIsLike, it traps all the records, even those non
>>> matching with the pattern.
>>> Is that a mapserver bug on WMS-SLD handling ?
>>> Thanks
>>> Oscar Gomez a écrit :
>>>> Hi Guillaume,
>>>> In the past it worked for me, but I had to look very carefully at the
>>>> symbology specification from OGC.
>>>> Here you are my example:
>>>> <sld:Rule>
>>>> * * <sld:Name />
>>>> *-* <http://www12.asphost4free.com/ogomez2/temp/wise.xml#> <sld:Title>
>>>> *-* <![CDATA[
>>>> * * </sld:Title>
> <ogc:Filter>
>>>> <ogc:PropertyIsLike wildCard="***" singleChar="*#*" escapeChar="*!*">
>>>> * * <ogc:PropertyName>*ORIGENAGUA*</ogc:PropertyName>
>>>> * * <ogc:Literal>*Subter**</ogc:Literal>
>>>> * * </ogc:PropertyIsLike>
>>>> * * </ogc:Filter>
>>>> <sld:PolygonSymbolizer>
>>>> *-* <http://www12.asphost4free.com/ogomez2/temp/wise.xml#> <sld:Fill>
>>>> <sld:GraphicFill>
> <sld:Graphic>
>>>> *-* <http://www12.asphost4free.com/ogomez2/temp/wise.xml#> <sld:Mark>
>>>> * * <sld:WellKnownName>*circle*</sld:WellKnownName>
>>>> * * <sld:CssParameter name="*fill*">*#A87000*</sld:CssParameter>
>>>> * * <sld:CssParameter name="*fill-opacity*">*1.0*</sld:CssParameter>
>>>> * * </sld:Fill>
>>>> * * </sld:Mark>
>>>> * * <sld:Size>*1*</sld:Size>
>>>> * * </sld:Graphic>
>>>> * * </sld:GraphicFill>
>>>> * * </sld:Fill>
> <sld:Stroke>
>>>> * * <sld:CssParameter name="*stroke*">*#A87000*</sld:CssParameter>
>>>> * * <sld:CssParameter name="*stroke-width*">*1*</sld:CssParameter>
>>>> * * <sld:CssParameter name="*stroke-opacity*">*1*</sld:CssParameter>
>>>> * * </sld:Stroke>
>>>> * * </sld:PolygonSymbolizer>
>>>> * * </sld:Rule>
>>>> I hope you find it useful. Best,
>>>> Oscar
>>>> On Fri, Jun 27, 2008 at 10:00 AM, Guillaume Sueur
>>>> <mailto:guillaume.sueur at neogeo-online.net>> wrote:
>>>> Hi
>>>> Has anyone ever had a PropertyIsLike filter working on a WMS layer
>>>> I have an SLD file with several rules, all of them with
>>>> PropertyIsEqualTo Filter. It works ok.
>>>> If I change one of these to PropertyIsLike (I add wildcard,
>>>> singleChar and escapeChar as well), they ALL go wrong, none of the
>>>> filters being used. All my objects are then shown with the default
>>>> representation placed at the end of the file without any filter.
>>>> Any idea about this strange behaviour ?
>>>> Thanks
