[mapserver-users] no geotiff in mapserver rpm?
Wendell Turner
wendell at enflight.com
Mon Jun 30 11:18:01 PDT 2008
On Mon, Jun 30, 2008 at 01:58:22PM -0400, Frank Warmerdam wrote:
> Wendell Turner wrote:
>> Why does the mapserv program in the mapserver-5.0.2-4.2 rpm
>> not support geotiff as input? Isn't geotiff a common format
>> for this type of application? Or is it that geotiff files
>> are served up as (plain) raster images with a shapefile?
> Wendell,
> How did you determine that geotiff is not supported? Generally MapServer
> is built --without-tiff allowing tiff support to be provided by GDAL.
> It might also be helpful if you indicated the source of the .rpm you are
> referring to since I don't think it is an official product of the project
> and there are a number of sources for rpms.
Thank you for the quick response.
The rpm was from one of the CentOS5 repositories, actual
rpm is mapserver-5.0.2-4.2.i386.rpm, I think I got it from
somewhere at rpm.pbone.net, possibly here
http://rpm.pbone.net/index.php3/stat/4/idpl/6383115/com/mapserver-5.0.2-4.2.i386.rpm.html.
mapserv -v does not show 'input=geotiff', which I thought
was bad. So then, the proper way is to generate a shapefile
for the geotiff file, have mapserver read the shapefile for
parameters, and use the gdal library to do the
geotiff/raster processing? Is a raster image with
associated shapefile about the same as a geotiff (as far as
pixels + metadata about the position, projection, etc)?
Thanks again,
Wendell
More information about the MapServer-users
