[mapserver-users] Changing map colors dynamically doesn't work
Michael Wessel
michael_wessel at gmx.de
Sun Mar 2 09:12:13 EST 2008
Dear MapServer list,
according to
http://mapserver.gis.umn.edu/docs/reference/cgi/controls
"Changing map file parameters via a form or a URL"
it should be possible to change the fill color
of my map polygons to blue via the GET parameter
map_lakes_class_color=0+0+255, e.g. in
http://localhost/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/test4.map&map_lakes_class_color=0+0+255
However, there is no change; the polygons stay red,
as defined in the reference map file:
MAP
NAME 'map'
STATUS ON
IMAGETYPE PNG
EXTENT -3037632.000000 -708658.398506 1846021.625000 4934649.999999
SIZE 1024 768
SHAPEPATH "/srv/www/mapserver/"
WEB
TEMPLATE "/home/mi.wessel/test/global.html"
IMAGEPATH "/srv/www/htdocs/temp/"
IMAGEURL "../temp/"
END
LAYER
NAME 'lakes'
STATUS DEFAULT
TYPE POLYGON
DATA lakes
CLASS
COLOR 100 0 0
END
END
END
I have also tried
map_layer_0_class_color=200+0+0
but then I get
getSymbol(): Symbol definition error. Parsing error near (0):(line 1)he error
What's wrong here? Adding a name to the class doesn't work either.
I am using MapServer 5.0.2 (2008-01-28) on SuSE Linux 10.2.
Best regards and thanks in advance,
Michael
