[MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation fault
rich.fromm
nospam420 at yahoo.com
Mon Mar 3 15:53:22 EST 2008
hrach wrote:
> I use mapserver 4.10.3, postgresql 8.1, Debian Etch.
> Is anybody using CLOSE_CONNECTION=DEFER without any problems ?
I am now using it fine with mapserver 5.0.0 after applying the patch for bug
2497:
http://trac.osgeo.org/mapserver/ticket/2497
I don't know if 4.10.3 is different enough for that patch to be applicable
or not. But if it's not too hard to upgrade, you might want to try a later
version (e.g. 5.0.2) plus that patch. Note that the patch may make it into
the 5.0.3 release (it was originally targetted for 5.2).
You also might want to take a look at the following related mailing list
threads:
http://www.nabble.com/Segmentation-fault---mapserver---postgis-to12653945.html#a12674499
http://www.nabble.com/postgres-transaction-warnings-to15749333.html
- Rich
View this message in context: http://www.nabble.com/CLOSE_CONNECTION%3DDEFER----Segmentation-fault-tp15786741p15813612.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
